I have a photo. It also looks like "DSMOS has arrived" doesnt show
Pls I need help
Hello again, I managed to fix that problem too it boots okay but it never manages to get on the recovery screen and its stuck on verbose boot. Here is my efi folder again (I had to remove AirportItlwm.kext so it decreases the archive size by a lot)
  • EFI.zip
    EFI.zip
I RAN INTO PROBLEM IM HAVING ERROR APPLENVME ASSERT FAILED LINE 5669
MY LAPTOP IS LENOVO 15ADA7 (RYZEN 5 VARIANT)
HERE IS MY EFI
AND IM TRYING TO INSTALL VENTURA WITH ONLINE INSTALLER (OPENCORE 0.9.3)
So the problem is I waited like 5 minutes to boot to the recoveryOS but it looks like it doesnt and its stuck on still giving me dmesg messages (Verbose boot). I tried Ventura and Monterey still the same issue. Maybe its NootedRed kext isnt loading properly or the config.plist is not configured properly. I dont even know :(. I really really want to install macOS on my PC!
Your configuration is not as per the guide. NootedRed is officially not released yet. Which commit kext you used? What are your BIOS settings? What macOS version are you trying to install?
alvarg82
