hello, guys, I had setup all things all goes well but after verbose and just before the language picker I got black screen, Here I smy configuration Amd Ryzen 7 5700g, Asus B450 motherboard, No Graphics card,32 GB RAM and Wd green data SSD...I am also attaching My Efi kindly please check
What macOS version are you trying to install?
Hello, it's my first time trying to hackintosh my PC, but when I try to run the installer it kernel panics right when the NootedRed kext is loaded. Also I can not view the full kernel panic info due to me having a 1366x768 screen.
I'm not sure what is wrong with this and I hope you will find a solution for this:)
Anyway here is my EFI folder attached:
The official OpenCore guide says to disable IOMMU from UEFI but here it says to keep enabled. Who should I trust??
Please provide access.
Okay, I'm not sure how can I allow downloads but here is the link again:
I RAN INTO PROBLEM IM HAVING ERROR APPLENVME ASSERT FAILED LINE 5669
MY LAPTOP IS LENOVO 15ADA7 (RYZEN 5 VARIANT)
HERE IS MY EFI
AND IM TRYING TO INSTALL VENTURA WITH ONLINE INSTALLER (OPENCORE 0.9.3)
  • EFI (2).zip
    EFI (2).zip
I had successfully install Macos ventura on my amd Apu 5700g..But Ios simulatir showing black screen and stuck..Inside log files error is. .. <Error>: Could not register service com.apple.gputools.agent.producer.sim: Failed to lookup com.apple.gputools.agent.producer.sim: 0x44e
It is cool that you managed to install MacOS, for me it doesnt boot and gives kernel panics. Any advice??
alvarg82
