Disable Nvidia GPU FANS on Dual boot
Slake
I'm running nvidia RTX on pcie slot 1 for windows and AMD on pcie slot 2 for hackintosh.
I have managed to disable the nvidia gpu via SSDT and it's not showing anymore in the System Information.
Is it possible to completely disabling the nvidia gpu fans as well? the GPU is not hot at all and fans spinning forever will wear down the fans faster
When disabled, it shouldn't be like that.
I have it disabled via SSDT inside ACPI. So I think it should have been disabled on ACPI level?
Attach your PR Files to confirm.
Listo
