I Can't update my hackintosh
alexouilleadria
  2. Clover (Legacy)
Hello!
When I want to upgrade my macOS monterey to macOS Ventura, it says "macOS ventura is not compatible with your mac".
I thought that the problem comes from my smbios. And the problem comes from there! I adapted my smbios to a smbios for macOS Ventura and after changing it my bluetooth no longer works.
I would like to know if it was possible to solve the problem of my blutooth.
Thanks!
My Config :
Intel Core i5-6200U with Intel HD Graphics 520
SSD Nvme 480go Samsung
8GO of RAM
Intel dual-band-AC 3165
Realtek Ethernet (idk the model of ethernet card)
Webcam 720p HD
USB 3.0 (2)
USB 2.0 (2)
HDMI (1)
Hello!
Thanks!
My Config :
8GO of RAM
Webcam 720p HD
USB 3.0 (2)
USB 2.0 (2)
HDMI (1)
It's normal. When you change the SMBIOS, you need to change the SMBIOS in your USB kext too. Otherwise, it will not match the SMBIOS and will not work. Attach your USB Kext.
Hi! Thanks for you reply! I understand that but how i can change my smbios in my usb kext??
Attach your USB guide and we'll guide you and update the main threads.
Hi! Sorry but i dont understant (but im french) :/
I'm really sorry but I don't understand the meaning of "attach" because it's difficult for me to understand you :(.
Damn 😕
Attach here means upload. In the area where you type (the message box), there is a "Attach files" button below. Use that button to upload the files.
oops i understant now! sorry i look stupid :(
It happens ;)
The USB Ports are not mapped properly.
ploukop
