Headphone jack not recognised HP Probook 440 G5
You can find them attached
You're having duplicate kexts installed. Remove the duplicate kexts from Library/Extensions
Duplicates as opposed to what? Clover/kexts/other?
Sorry but I'm kinds nervous doing that, is it not better to remove the duplicates from the clover/kexts/other, as they can be put back more easily ?
Ok, I got rid of the duplicate files in Clover/kexts/other but nevertheless if I put the laptop to sleep the headphones are not getting recognised. However if I left them plugged in (even though they're not recognised) then put the computer to sleep and wake it the output changes to "headphone port" and the sound comes from the headphones and if I unplug them it stays on "headphone port" and I have no sound from the speakers unless I put it to sleep and wake it again without the headphones.
Update: I stumble upon this (same problem for a real mac) and they suggested the following:
sudo kextunload /System/Library/Extensions/AppleHDA.kext
sudo kextload /System/Library/Extensions/AppleHDA.kext
sudo pkill coreaudiod
when I did it I had the headphones running again (after sleep), so I suppose it's a problem with the loading of the kext after sleep. I have CodecCommander installed but maybe it should be configured somehow? or something else?
No need to be nervous.
New PR files not attached.
Hello, I'm sorry I'm bringing this up again but I didn't use my hackintosh for a while and saw something which is not ok. The audio output swithching stops working after sleep. For exemple if I'm on laptop audio put the laptop to sleep and wake it if I plug in the headphone jack it doesn't get recognised OR if I'm on a hedaphone jack and put it to sleep and wake it, after sleep if I unplug the jack the output stays on "headphone port" and doesn't switch to computer audio. if I reload audio kernel with the following command it starts working as it should
is there a way to solve this.
ilikeeatingpeeandpoo
