Booting macOS installer on laptops can be a challenge for the new users. This guide covers a complete step to boot the macOS installer on your Laptop using Clover bootloader. Those who are not using Clover, can update their configuration for clover and continue to use it.
Clover is one of the most advanced bootloader yet and it can boot upto almost any OS. With this, it has several advantages.
If you're having a laptop which is UEFI capable, follow the UEFI guide.
If you're having a laptop which doesn't have UEFI capabilities, then follow the Legacy guide.
Get your hardware details
Before you start, get to know about your hardware. Starting your journey without knowing your hardware will make your journey difficult with no any chance of success. Also when seeking for support, the hardware details should be present in your profile.
Read here: https://www.elitemacx86.com/threads/read-me-first-laptop-compatibility.133/
https://www.elitemacx86.com/threads/faq-read-first-frequent-questions-related-to-laptop.136/
Creating a Bootable USB Flash Drive with Createinstallmedia
The next step is to create a bootable installation drive.
To create the installation USB, createinstallmedia method is recommended and is only valid method to prepare the installer.
For Catalina:
For Mojave:
For High Sierra:
For Sierra:
At this point, the bootable USB can be only used to boot Mac only. In order to boot the laptop using the USB, follow the steps below.
Note: Minimum 8GB of USB is required. For High Sierra and later, 16GB is recommended.
Installing Clover Bootloader
1. Download Clover EFI Bootloader
2. According to your laptop, either Legacy or UEFI, install the Clover Bootloader.
3. Extract the Clover EFI bootloader installer package and right click on the .pkg file and select Open.
4. By default, the Clover Bootloader will select the system drive i.e Macintosh HD. Simply click on Change Install Location and select your installation Drive i.e Install macOS High Sierra.
5. Click on Customize and configure the following settings.
For UEFI:
If you’re using a UEFI based laptop, then it’s recommended to install Clover as a UEFI. Configure the following options for UEFI.
If you’re using a Legacy BIOS, then it’s recommended to install Clover as a Legacy. Configure the following options for Legacy BIOS.
6. Confirm the above options and click on Install. When promoted, enter your password. The clover bootloader will be installed to your installation drive.
7. Once done, simply click on Close.
Downloads
8.Copy the additional drivers to: /EFI/Clover/drivers64UEFI
Now you’ve successfully installed clover and the required drivers on your USB. After installing the Clover bootloader, the EFI partition should be mounted on your Desktop.
Placing required kexts
In order to boot into the installation, you need to place the necessary kexts. Follow the guide below to place the necessary kexts.
Navigate to: EFI/CLOVER/kexts/
Remove all the folders, 10.x, except 'Other'.
Downloads
Navigate to /EFI/CLOVER/kexts/Others/ and place all the 5 kexts (Lilu.kext, VirtualSMC.kext, WhateverGreen.kext, USBInjectAll.kext, and VoodPS2Controller.kext)
When installing Clover, it places a default config.plist file. This config.plist cannot be used to boot most of the laptops. You'll need to configure the config.plist according to your hardware, mainly graphics and other devices.
Once again, Thanks to RehabMan who made this easy for us. You can select a config.plist which matches to your hardware from his repository : https://github.com/RehabMan/OS-X-Clover-Laptop-Config.
It's easy to select among the list of config.plists. You can look at the config.plist and select the appropriate config.plist according to your graphics and screen resolution.
Suppose, if your laptop uses Intel HD Graphics 520, then select "config_HD515_520_530_540.plist". If your screen resolution is 1366x768, use that one. The screen resolution only applies to Intel HD Graphics 3000 and 4000.
The later series doesn't depends on the resolution.
The graphics kext requires DVMT-prealloc to be set to 64mb or larger. This has become necessary from the Broadwell graphics. Commonly, the laptops manufacturers sets the DVMT to 32MB which isn't sufficient and will likely result in a kernel panic.
There are few ways to set the DVMT even if your BIOS doesn't have option to set. But remember, they are risky!
You can read more about DVMT in the laptop FAQ.
Since most laptops come with insufficient DVMT-prealloc, the plists by RehabMan includes a 32MB patch by default.
Also, even if the patch is enabled, you can still get panics. It is because Clover cannot patch a kext that loads outside of kernel cache, and these graphics kexts may not be in cache. To fix this issue, there's a workaround from RehabMan. Just use an invalid ig-platform-id (0x12345678) and then boot to the installer. Do not use an invalid Fake ID as it will not serve the purpose. Once you are able to boot with the invalid ig-platform-id and enter your desktop, rebuild cache, then boot normally with your required ig-platform-id.
To rebuild cache, you can use Terminal:
CPU Power Management
With some old Laptop hardware such as Sandy Bridge, if you get a kernel panic related to AppleIntelCPUPowerManagement or ACPI platform, you need to drop the OEM SSDTs. A quick way to fix is to check "AppleIntelCPUPM" in Kernel and Kext Patches section of your config.plist. Once you install the OS, you can patch the SSDT for CPU PM. To read more about CPU PM, read here.
Now, the USB Flash drive is ready to boot off your computer.
For Catalina:
sudo /Applications/Install\ macOS\ Catalina.app/Contents/Resources/createinstallmedia --volume /Volumes/USB
sudo "/Applications/Install macOS Mojave.app/Contents/Resources/createinstallmedia" --volume /Volumes/USB --nointeraction
sudo "/Applications/Install macOS High Sierra.app/Contents/Resources/createinstallmedia" --volume /Volumes/USB --nointeraction
sudo "/Applications/Install macOS Sierra.app/Contents/Resources/createinstallmedia" --volume /Volumes/USB --applicationpath "/Applications/Install macOS Sierra.app" --nointeraction
For UEFI:
- Install Clover for UEFI booting only
- Install Clover in the ESP
- Themes: BGM (You can select any)
- Drivers64UEFI: OsxAptioFixDrv-64 or AptioMemory Fix and ApfsDriverLoader-64
- Bootloder: Install boot0af in MBR
- CloverEFI: CloverEFI 64-bits SATA
- You need one additional driver. HFSPlus.efi
- Without HFSPlus, you won't be able to see any HFS+ volumes including your installation drive.
Downloads
Downloads
- Lilu.kext
- VirtualSMC.kext
- WhateverGreen.kext
- USBInjectAll.kext
- VoodooPS2Controller.kext
- Use the kext from RELEASE folder and RELEASE.zip file.
- Do not place unnecessary kexts here. It might prevent booting the installer.
- Only use basic kexts which is required to boot off the installer. You can install the rest required kexts at the time of post-installation.
- The VirtualSMC package includes Battery and Sensors plugins (SMCBatteryManager.kext, SMCDellSensors.kext, SMCLightSensor.kext, SMCProcessor.kext, and SMCSuperIO.kext). You do not need these kexts for booting the installer.
- If your SATA uses RAID mode instead of AHCI mode, you'll need to use an injector. This can fix no drives detected at Disk Utility.
- If you have an unsupported SATA controller (8086:a103, 8086:9d03), use SSATA-unsupported.kext. This will fix the above mentioned issue(No drives detected at Disk Utility).
- If you're using a M.2 SSD, and plan to use Sierra, read the NVMe compatibility covered in FAQ: https://www.elitemacx86.com/threads/faq-read-first-frequent-questions-related-to-laptop.136/
- Download the entire Zip from using the Clone or Download button to get all files.
- Clover can only recognize config.plist file so make sure you rename the copied plist to config.plist.
- Always use -v (verbose option) so that you can track the progress of the installer and the errors encountered.
- If you get any kernel panic due to the graphics, due to DVMT-prealloc, use an invalid ig-platform-id (0x12345678) to boot to the installer and fix the graphics later on, at the time of post-installation.
- If your laptop has DVMT-prealloc option, set it to 64MB Only.
- If you're having a QHD/UHD/4K Display, then set the DVMT to 96MB or 128MB.
- If you've option to set the DVMT, remove or disable the 32MB patch from your config.plist.
sudo kextcache -i /
