high sierra error impossible contact the server
Can you link me one method?
I was having the same issue. I somehow got it fixed in a VM on KVM and then burned the disk image to a drive
It's an issue with the actual installer volume, I'm pretty sure.
It requires MacOS but I'm saying hackintosh Ventura without acceleration (nv_disable=1), then use that installation of MacOS to create the offline installer. Then the user could install MacOS High Sierra without issues
It's not a matter of installation. The user is trying an online method (recovery). The solution is to use an offline installer.
True, and the way to get the offline installer is to use MacOS and the createinstallmedia command as described in the Dortania article
Use the Hackintosh technique to install another version
I've personally tested other versions of online installers and they work without issue. High Sierra's online installer is the issue
ryusuke17
