Headphone jack not recognised HP Probook 440 G5
jonny33
Laptop
i5-8250U
Intel UHD 620
10.15.x
Hi there I have the aforementioned laptop with clover everything works apart from the headphones jack. Whenever I plug it in it doesn't get recognized at all. My audio codec is CX8200 and the installation is clover with hotpatch method. Do you have any idea how to fix that?
Thanks in advance
Thanks in advance
No PR files attached.
I'm not on the laptop but I didn't made any changes since the ones attached, so there they are
I followed your guide and I don't have sound at all. Please help, files attached
Remove duplicate kexts. Use AppleHDA from Patcher. You should be good to go!
After using patched appleHDA and removed AppleALC and fakepciidhdmiaudio it's working like a charm
Hi, again, I noticed that the headphone jack actually is not working after sleep and the computer needs to be restarted in order for it to work again. Do you know what may be causing this?
javirodasg
