high sierra error impossible contact the server
I cant get to this screen where i select the drive..i have only the first continue and the error
The Disk might be faulty then as it is failing to convert the disk into APFS. Restart the system, reset NVRAM twice and then check.
I try in 1 hour and half..
For reset nvram i need have only the driver right?
Okay thanks a lot for helping me
On sanitychecker say i have missing file: allownvramreset...and normally is set to yes
Nvram reset not work
lucadita
