How to Add Boot Args [Clover/OpenCore]
An EliteMacx86 Exclusive Guide - This guide covers adding boot args in Clover and OpenCore.
Boot Arg is required for several purposes and there are different boot args to serve different purposes. Boot arg can be added to Clover and OpenCore. To add the boot args, follow the steps below.
elitemacx86.com
Clover
If you're using Clover as a bootloader, follow the steps below to add boot args.
1. Mount your ESP.
2. Open your
3. Add the required Boot Args under Boot Arguments in the
4. Save your
OpenCore
1. Mount your ESP.
2. Open your
3. Add the required Boot Args under the
4. Save your
INFO - Common Boot Args for macOS [Clover/OpenCore]
Common Boot Args for macOS [Clover/OpenCore] Booting macOS requires some boot args. Boot args are also known as boot flags. There are several boot args used for different purposes. There are some common boot args and some are kexts specific. This is a list of common boot boot args for macOS...
Clover
1. Mount your ESP.
2. Open your
config.plist
using any XML editor from the EFI/Clover
directory.3. Add the required Boot Args under Boot Arguments in the
Boot
section of your config.plist
.4. Save your
config.plist
.OpenCore
1. Mount your ESP.
2. Open your
config.plist
using any XML editor from the EFI/OC directory.3. Add the required Boot Args under the
7C436110-AB2A-4BBB-A880-FE41995C9F82
UUID list in the NVRAM
section of your config.plist.4. Save your
config.plist
.NOTE:
