Hello I can not find the workaround?
Or is it not there yet.
You can use the new version of OCLP which will handle it.
OLCP is for a real mac ? or olso for a hackintosh?
Targeted for real Macs. However, can be used with non-Apple systems as well.
I was able to install macos ventura but my problem is if I try to turn on my macbook air 2017 without the usb, it wont boot in unless I plugin the usb installer. It only boots into macos ventura when i plugin the usb installer. Please help me
You'll need to configure postinstall to the system disk.
daemon6109
