Two graphics cards setup: RX 7900 XTX and RX 550 (Lexa)
I think that's better ))) The second card was disabled by SSDT. See in attach. But you must enter your PCI path!
Looks good now. Of course, the ACPI path must match the GPU you want to disable. It's already covered in this guide.
So, today I booted up macOS and had a black screen. I changed the SSDT method on the old Device Property method and all work.
When I use SSDT my GPU is recognized like AMD Radeon Polaris 4 GB. When I use the Device Property method I have AMD Radeon RX 550 4 GB.
That's because the SSDT you're using has the model. You can change it easily.
What are the PR Files? EFI?
FAQ:
Here is EFI
Here is EFI
Here are a few issues.
- Enable RebuildAppleMemoryMap and SynRuntimePermissions in Booter>Quirks section.
- Remove all Device Properties.
- Enable PanicNoKextDump and PowerTimeoutKernelPanic in Kernel>Quirks section
- Add alcid=1 and remove e1000=0 from boot args.
- Remove HfsPlus.efi and use OpenHfsPlus.efi.
YES - Enable RebuildAppleMemoryMap and SynRuntimePermissions in Booter>Quirks section.
YES - Remove all Device Properties.
- Kexts loading order is not correct. Important Kexts should load first. - What is wrong with my order?
My order is:
- Lilu.kext
- VirtualSMC.kext
- WhateverGreen.kext
- SMCProcessor.kext
- SMCSuperIO.kext
- SMCRadeonGPU.kext
- RestrictEvents.kext
- USBMap.kext
- RadeonSensor.kext
- AirportItlwm.kext
- BlueToolFixup.kext
- IntelBluetoothFirmware.kext
YES - Enable PanicNoKextDump and PowerTimeoutKernelPanic in Kernel>Quirks section
- Add alcid=1 and remove e1000=0 from boot args. - I don't use AppleALC (I have USB sound card integrated into my mobo.) e1000=0 - this need for my network.
- Drivers loading order is not correct. Important Drivers should load first. - What is wrong with my order?
My order is:
- OpenRuntime.efi
- OpenCanopy.efi
- OpenHfsPlus.efi
- ResetNvramEntry.efi
- ToggleSipEntry.efi
YES - Remove HfsPlus.efi and use OpenHfsPlus.efi.
xxxxxxxxxx
