Kernel Panic AppleACPIPlatform in Ventura
glucas
Premium Member
z690
i7 12700
Hi can you help, I've been trying to figure out this issue for days,
Kernel Panic AppleACPIPlatform on Ventura
The docs from dortania did not help as well: https://dortania.github.io/OpenCore...tml#kernel-panic-appleintelcpupowermanagement
Here's a screenshot of that error.
Im using OpenCore-0.8.8-RELEASE
Here's my EFI https://drive.google.com/file/d/1iL_awDuJu6nDTtC2ELTrTGnAXY1s7oTR/view?usp=sharing
Specs:
CPU: i7 12700k Alderlake
Motherboard: Asus z690-i wifi
RAM: 32gb DDR5 kingston Fury
GPU: Radeon 6600
Specs:
GPU: Radeon 6600
while I was waiting for your reply I already started using this guide.
Do you think I should stop my progress here and use your guide?
we almost have the same specs
You should be good with the above guide. It's more specific for Alder Lake builds.
Hi! I followed the instructions but now I get this message
this is the contents of my usb installer
and this is my EFI folder
And when I change the value of the vault from "Misc-> Vault" to "Optional" that message was gone but there's no option to install the OS just resetNVRAM
Opencore: OpenCore-0.9.1-RELEASE
OS: Ventura
OS: Ventura
Your configuration is still not as per the guide. Seems like the cleaning part has been totally skipped.
I did not skip the cleaning. I removed all the unwanted drivers and left only what I need.
can you see the EFI on my google drive?
Reactions: glucas
Hi Thanks for the reply, I updated my EFI based on your guide.
But now it wont even boot, when I try to boot on the usb it just returns me to the BIOS
Note: this is opencore 0.8.8 because I can only find same version of this (OCAT)
The basic rule is you must use the same version of OpenCore, config.plist and the XML Editor. To avoid issues, grab OpenCorePkg and copy the sample.plist and then start editing it as per the guide. It's all well explained in the guide.
Rhombus
