Disable Show Picker
YosiCoco
msi z490a-pro
i7 10700k
intel UHD graphics \ GTX 1660 super
  2. Other
i tryed to disable the option "show picker", wen i booted It will boot straight into windows, how fix that?
i put here my EFI
i put here my EFI
You need to have working NVRAM or Emulated NVRAM.
In the OC Boot Picker, select the OS you want to boot as default and then press Control + Enter on the Keyboard. This tells OC to bless that drive as the default OS to boot.
If you turn OFF the Boot Picker (by setting ShowPicker=False) and reboot, then hold the ESC key to show the boot picker otherwise it will boot the default OS (setup previously).
ANARKRUTOI
