- Mar 18, 2019
- Dell XPS-9350
- i7-6560U
- Intel HD540 (Iris)
- 10.14.x
- Clover (UEFI)
Hello,
I think I'm finally at the best place to describe my issues. Love the XenForo-Software and the general style of this forum.
So I've bought a Dell XPS13 (9350) Notebook which has the following specs:
The Problem:
I've changed the SMBIOS to 13,1 to match my Specs a bit better.
Booting with enabled verbose-log outputs this:
busy timeout[0]: IntelFBClientControl
It loops three times until a new Error arrives:
newUser: waitQuietController failed: AppleIntelFramebuffer
This loops three times also. You can see the errors clearly in the attached Screenshot.
So what have I tried so far?
- I've changed the SMBIOS to 9,1; 11,1; 13,1 and 14,1
- Created a barebone Stick with no patches and only essential kexts. No luck either. Same error.
- Perform an EC-Reset
- Patch DVMT
- Using other Repos for the XPS9350, which all ended up being the same (error-wise)
- Tried with HighSierra and Mojave
But there's one more thing!
If I inject a Fake-ID (0x12345678)
and a (invalid)*-fake-platform-ID, the boot proccees gets past the FBClientControl-Error.
I'm able to move my mouse around the verbose log, which just stops at "gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0"
After this issue arrived nothing happend further, I can't get to the installer whatsoever.
Sometimes it boots past the verbose log until I see an Apple-Logo and a progress bar, which is 0% filled, but here as well: I'm able to move the mouse around but can't get any further from here.
You can see that in the second Image I've uploaded:
So where do I go from here? Seems like nobody got a solution (I've tried to describe my issue on many other platforms as well), which really makes me sad - I really want this puppy to run!
Any help and advice is appreciated, my English might not be the best.
Thank you all very much!
~Daniel
P.S: I'm not able to upload my EFI-Folder right now, since I'm not at home yet. But beside the SMBIOS which is 13,2 in the Repo (should be 13,1) it's exactly the same as from the repo linked above.
- FHD-Display (1920*1080edited, see post #5)
- i7-6560U (therefore an Intel Iris HD540 Graphicchip)
- 8GB DDR3 RAM
- M.2 SSD from Toshiba
- and a Broadcom WiFi-Adapter
The Problem:
- Patch DVMT
~Daniel
