If you really want to make it real quick, rather than watching the guide and fixing your current EFI, just start from scratch by following the guide. It has worked always. Rest is your wish what you want to go with!So: I'm starting again in small steps from my efi that was going. Now I clean up one step at a time and restart and see when it doesn't restart again. Surely if you set the booter quirks for Raptor Lake as per the guide in the video, the PC won't start. That's for sure. Now I'm seeing more and then I'll update you
You don't need to change one thing, save the config.plist and check if the system boots or not. That's the wrong route and so much time consuming. Its way better to follow the video from scratch, build a new EFI with things fixed in the first place!
If you do the same thing today, there is no outcome for the discussion we had yesterday ;(
