Hyper-V (success-ish)
Thanks for your reply.
For the last 3 days, it is according to this instruction that I have been trying to install macOS on hyper-v.
I've started all over again several times, but the result is always the same.
The virtual machine image, EFI and config.plist that I downloaded in this topic gives the same errors as my own config.plist.
Most likely I'm wrong somewhere, but I don't understand where.
You didn't make the changes or start from scratch using the above guide. If you think you did, attach the EFI to check your work!
Here is my current EFI. It is no longer quite in its original form - it is the result of experiments. So far I have not been able to find a single parameter that would lead to changes. Probably, a combination of some parameters will lead to changes.
I was able to move on by replacing MacHyperVSupport.kext with MacHyperVSupportMonterey.kext
In principle, it works.
The installation took about 3 hours, 4 or 5 reboots, a bunch of some errors flashed on the screen, but it started.
It works very slowly, apparently because of the video adapter, need to figure it out.
Who cares - here is my current EFI. There is still not everything right, apparently, but it already allows to achieve results as in the screenshot.
  • EFI.zip
    EFI.zip
Well, the configuration is not as per the guide.
You won't be able to passthrough the PCI Devices at the moment. In short, the Graphics will not work for now.
Yes, during the boot process, according to the logs, I see that not everything is good. I will continue to understand. Thank you.
Sounds good!
krash65
