GUIDE How to use Android USB Tethering on M1 Macs
before I try that, the github page says that it does not support M1.
"It seems that it does not work on Mac M1 Apple chip, working only for Mac Intel."
and also: https://github.com/chris1111/Wireless-USB-Big-Sur-Adapter/issues/151
so the question is how you made HoRNDIS work in M1, and maybe we can do the same for that WiFi adapter kext
You should try to follow the instructions I provided and then after your reports, I can conclude a result. As I already mentioned, I tested 2 Adapters with the same Chris1111 drivers and they work perfectly.
Reactions: jdo
does not work.
I think it's because:
1. the first adapter - TL-Link T2UH is with MediaTek chip and doesn't even have the drivers in the kext.
2. the second adapter has the Realtek 8821CU chip, but the drivers for that are also missing from the kext: you can see under sub-title "Support Drivers: (Adapter)" many 88XX drivers, but not 8821.
also - I'm not sure how it works for you on M1 since there are 3 github issues on M1 being unsupported.
does not work.
Note that my chip was different.
Hello @EliteMacx86,
thanks for the explanation on How to use Android USB Tethering on M1 Macs, it worked for me.
I just have a quick question :
should I setup my Macbook Pro back to max level security ? Kinda like "revert" STEP 1.6 ?
If so, would you be able to explain me how ?
Thank you !
Hello @EliteMacx86,
Thank you !
You should be able to revert it. You can just boot into recovery and via Utility, you can select the desired option. If selecting the Maximum Security disables the kext loading, you must set the security to reduced.
It works for me, thanks!
Can I roll back security changes? Will it stop working in that case?
It may stop loading.
---WARNING ----
I followed the first steps but then it said it needed to change security permissions to install system extensions now when I reboot to try and load terminal in recovery mode it comes up error saying security must be enabled. The only option is to quit. And round the loop goes. Mac will boot ok but I cannot progress with installing Horndis on m1 mac with montery.
Anyone got it working?
---WARNING ----
Did you set the Mac to Reduced Security?
mykal
