Yes, it's required.
Update. I've disabled Thunderbolt completely in BIOS but OS still sees the card and now KP is gone but it automatically wakes after sleep.
Update V2: It was only temponary. When I turned off my pc for a while it disappeared.
Quick question before i post PR files: My Titan Ridge is successfully flashed with NVM50-CaseySJ firmware. Trying to follow the SSDT creation guide, and can't understand where the single-slot instruction ends and multiple-slot instruction begins. So basically i changed only the PCI0>PC00 clicked "all" then "done" compiled and saved. Then put the result to Clover/ACPI/Patched together with SSDT-DTPG. No hotplug, did i missed anything?
Are you issues fixed now?
Yes, you missed the address adaptation.
Hi and thanks for the tutorial. Im having issues with my Alpine Ridge ( not flashed ). I set the SSDT following the tutorial but the system is stuck at apple logo on boot , the bar doesn't start to load. Then if I use a pre made SSDT that I found on the internet I can boot BUT the devices are recognized only after reboot. Any help will be appreciated and I'm leaving my IOreg screenshot just in case. Thanks
hubalala
