Hi Administrator i need help,
sharewebonic
Beelink SEi 12 Pro
Intel® Core™ i7-12650H
Intel® UHD Graphics
But I am installing Olarila Hackintosh succeed, but some drivers missing, for example graphics (resolution) Wifi and Bluetooth not Working But run. Basically, if the graphics driver is not there, then why should the graphics driver not work? There is no life of computer without graphics only darkness Okay, but this is Intel UHD Graphics. You can see this post:" "
Why you don't understand that the Alder Lake IGPU isn't supported on macOS?
You can install macOS on an unsupported Graphics, but the Graphics will NEVER WORK!
drewcz1
