Clover EFI FB Issue, PowerManagement, ACPI Insight RequestedL
fspkwon
Dell Latitude E6520 SandyBridge
Intel SandyBridge
NVS 4200M Fermi nVidia OPTIMUS (Working)
10.13.x
  2. Clover (Legacy)
Bootloader: Clover EFI/CSM Mode trying to make it so i can boot either or..
Working: PS2 Alps Touchpad Mouse EFI/BIOS..... Meaning in clover...
I installed the Speaker Driver but havent tested it... it is Themed...
Kexts: It is to my Understanding when using BIOS you require a Patched AppleIntelCPUPowerManagement.kext ....................... but was able to boot without it....
FakeSMC - Using the Latest Branch with Expects: DSDT Plugin........... for SuperIO.....
HPET: I still have a list of IRQ Conflicts im sure is contributing to the Freezing..............
HDA: ALC_ID=12 Working....................
USB: Causes Clover-EFI to Panic................
SMBUS-LPC-SMC-X86PlatformPlugin : This was a WIP but im scrapping my Tables and starting over....
Pointers: I want to know what about this drop DMAR and CPU0IST and MCFG is required............ for SandyBridge its a SandyBridge....... and PSTATE Panics.... as it currently is and Stalls at NVHDA and SMCPlugin... it Timeouts...
Clover in EFI Mode: Has no Text Console just stops at the END *********************
Will This Fix It although i find not a single one compiled: GraphicsConsoleDxe.efi
You use DisableIoMapper and that way it will have no affect with the DMAR. CPU0Ist dropping is required during install phase. But once you have implemented the PM, it should be fine.
Snowson
