SOLVED AMD RX580 Low performance on big sur
insov
Machinist X99Z v102a
Xeon E5-2620 v3
Sapphire Nitro+ RX580 4GB
10.13.x
Hello everyone.
My system: iMacPro1,1 / 2620v3 / RX580 4GB / X99 v102 / DDR4 16GB 1866 / SSD SATA 512 / macOS 11.7.4 / OC 0.8.9
In short: when you turn on the hackintosh, the video card gives a low result on the graphics (first link), also the consumption of 300mhz gpu / 300mhz memory in idle is about 60-70watt that's a lot. BUT IF you put the computer into sleep mode and get out of it, the consumption becomes normal and the results in geekbench OpenCL or Metal are almost 2 times more! also after sleep and video card consumption comes back to normal (screenshots) (second link)
As it should be. What could it be, who has encountered such a bug?
I tried to attach pr files, if I did something wrong please let me know.
https://browser.geekbench.com/v5/compute/6444667
https://browser.geekbench.com/v5/compute/6444669
Reactions: zll2002
Hello everyone.
View attachment 5558View attachment 5559
Well, this is a known bug with Big Sur and above. Till Ventura Beta, the fix was to use an iMac SMBIOS. Probably, an issue with the SMU firmware loading.
Reactions: insov
you helped me very much. smbios imac19.1 helped me a lot! thank you so much! but i have one more little question, it is about sleep, not about graphics. can i ask you here, or should i create a new thread in another thread?
Well, as per the SMBIOS guide, iMac SMBIOS always expects an IGPU which normally Xeon CPU does not have. You can read about it here:
Marking this thread Solved. Please create a new thread for the questions or issues you may have.
Reactions: insov
ryusuke17
