It would be possible to install intel uhd graphics on pentium silver n6005, 0x4e71
karle
msi alpha 17 c7v amd ryzen 9 7945hx 610m
amd ryzen 9 7945hx
AMD Radeon 610M
12.x
  2. OpenCore (UEFI)
It would be possible to install intel uhd graphics on pentium silver n6005, 0x4e71?
Although it is a gt1, there are several threads on how to install in gt1, I think generating the framebuffer.
Thanks in advance
others users I have been told:
Starting with macOS Sierra 10.12 and later, the AVX Instruction Set is required to enable QE/CI acceleration of Intel iGPU.
Also, if the CPU does not support AVX2, the macOS Ventrua 13 version will not boot and Metal acceleration will not work.
The Intel Pentium Silver N6005 CPU does not support AVX, AVX2.
But, there is a case in which QE/CI was enabled on the Intel 4th Gen Haswell GT1 iGPU using OPEMU, which emulates the AVX, AVX2 instruction sets.
However, I think you should try to see if the Opcode Emulator (OPEMU) works on your Intel Pentium Silver N6005 CPU.
https://www.insanelymac.com/forum/topic/329704-opcode-emulator-opemu-plug-in-project/
Also, the Intel Pentium Silver N6005 CPU is not supported by macOS.
Even installing macOS may require a fake CPU ID or a specific patch.
some occurrence?
As indicated in the Intel Graphics Compatibility guide, GT1 (Low End) Graphics isn't supported on any macOS/OS X version.
This is more about brining support for unsupported CPUs, not Graphics.
some occurrence?
Yes, you may need CPU ID patch along with XCPM patch. A guide will be there very soon.
biff
