You mean this?
Reactions: KVyDavid
Also, can you try 10.4.8?
I’ve reinstall macOS a few times before but this problem still exist. Maybe I’ll try 10.4.8. Do I have to change anything in config?
Which version you specifically tried to install?
Actually, try 10.4.6. Your configuration seems fine.
I install the latest version of macOS Monterey
Right, 10.4.6. I mistyped it😅
I can only find macOS 10.7 on Apple's website. 10.4.6 is pretty old so I'm afraid FCP X won't be able to open my current FCP library to export it.
Oops. Then we have a problem here.
bobawoz
