Thank you for your replies! I might go with AMD in the future then.
Intel CPU+AMD GPU is the best combination in terms of Desktop for this specific purpose.
Would it still be usable without a GPU… or an IGPU I gues?
Without graphics acceleration, the performance is nearly similar to VMware or Virtual Box.
is Mac OS Venture still doesn't support Nvidia 1660 Super?
See compatibility:
@Ygor
Finally, Skylake (Intel HD Graphics 520) is working with full acceleration.
Guide:
Hi Which App are using to show all hardware info Thanks
Still not able to generate it. If I give my PC specs can you or someone give me the files?
Your help would be greatly appreciated.
Reactions: kwsa2024
It's your responsibility. What are you not able to generate?
I have a problem with the brightness of the DELL INSPIRON 7580
I was able to upgrade from Monterey to Ventura
This is my EFI folder
Can anyone help me?
Can anyone help me?
Better to switch to OpenCore. Start here:
I solved it with configuring the Config.plist
properly, however, the LAN network and bluethooth card is not working
Inside the zip I have removed
AirportItlwm.kext
IntelBluetoothFirmware.kext
IntelBluetoothInjector.kext
Otherwise the size was too much to attach
I switched from Clover to OpenCore
(Easiest Opencore for me to set up)
Now the brightness is ok
Jycs
