ok got orico T3 usb-c with SSD NVME gen4 result maple ridge doesn't work not showing up
it's from windows
it's from windows
What are the BIOS Settings? Are Drivers installed on Windows?
let me reboot
still copy need to wait for an hour argh
need to find the good SSD NVME case
Yes! I have the older version of ACASIS 40Gbps M.2 NVME SSD Enclosure. https://a.co/d/3RBpDqL I bet the newer version is better.
IT is great, as it is Thunderbolt 4, and it is backwards compatible with all USB, down to USB 2.0. So you can use it on any computer. Whether or not is has Thunderbolt. With my ThunderboltEX 4 card, my NVME shows up in the NVMExpress section, and it shows that it is x4 width.
With my Silicon Power 2TB NVMe, I am getting 1023.7 write, and 2635 read.
I got Asus ProArt x570 Creator Wifi motherboard and it has built-in Thunder4 but I don't knows what controller type belong to these 3 controller (JHL8340 or 8540 or 8440). only able to know under Windows Device Manager is Thunder Controller-1137. and i'm looking for guide how help me make it work on Big Sur. i'm very newbie on these kind.
You can check the controller in Hackintool>PCIe
1. I use DP passthrough to DP-in.
2. I use thunderbolt4/3 to hdmi cable to connect to thunderbolt port
3. I can't find thunderbolt when searching on IORegistryExplorer program.
4. this is cable that I use. https://www.amazon.com/Dockteck-Thunderbolt-Braided-High-Speed-MacBook/dp/B09BQXSGPB/ref=sr_1_5?crid=2C6W6A7XXM60O&keywords=thunderbolt+4+to+hdmi&qid=1677613438&s=electronics&sprefix=thunderbolt+4+to+h,electronics,130&sr=1-5
5. No SSDT use for thunderbolt.
Does this mean it working properly b/c monitor is working. spearker also work.
Although, Thunderbolt will work, without the SSDT, but will lack the HotPlug capability.
NCC74656
