How to Enable Temperature Monitoring and Fan Control on macOS
An EliteMacx86 Exclusive Guide - This guide covers temperature monitoring and fan control on macOS for PC and Laptop users.Overview
The Hack users have been using HWMonitor since a long time which uses FakeSMC and other related sensors for hardware sensing. Since, the release of VirtualSMC, it has been difficult to monitor temperature and fan control. However, there's a progress with HWMonitor2 which uses VirtualSMC instead of FakeSMC.
An alternative to HWMonitor is iStat Menus from Bjango which offers 14 days free trial.
Following are the requirements for enabling temperature monitoring and fan control.
| Kexts | Notes |
| VirtualSMC* | SMC Emulator and is required to boot the system. |
| SMCProcessor* | SMCProcessor is required for CPU sensing. |
| SMCSuperIO* | SMCSuperIO is required for fans reading. |
| SMCLightSensor* | Required for Ambient Light Sensor on Laptops. |
| SMCDellSensors* | Only required for Dell systems supporting System Management Mode (SMM). |
Notes:
*Requires Lilu.kext to function.
SMCBatteryManager.kext must be installed for Battery Meter monitoring. Enabling Battery Meter will also require DSDT patching.
Enabling Temperature Monitoring and Fan Control
Now, you know about the requirements, you can continue following the guide to enable temperature monitoring and fan control.
Adding SMC Sensors Kexts
To enable the hardware sensing and monitoring, you'll need to the sensor kexts.
Mount your ESP using OpenCore Configurator.
For Clover:
If you're using Clover, copy the required kexts to EFI/Clover/Kext/Others
For OpenCore:
If you're using OpenCore, copy the required kexts to EFI/OC/Kexts. You'll also need to add the kexts entries in Kernel section of your config.plist
Restart your System
Install iStat Menus
1. To install iStat Menus, visit this link and click on Download. If you want to buy or already have a subscription and need to upgrade, you can do so by clicking on "Buy or Upgrade" button just right next to the Download button.
2. Open the .zip file.
3. Double click on iStat Menus and click on Install.
Notes:
For real Mac users, you don't need to add any kexts. Just install iStat Menus and you should be good to go.
iStat Menus does not support MacPro7,1 SMBIOS yet.
Now, you can monitor the temperature and control Fan speed
