V4.1 has crashing and brightness issue.
v5.1 switches to Headphones but no Audio. When i use my script, it works but no ComboJack and again, the Output of Mic is very crappy.
v6 has no Microphone
Works more good than all earlier versions but no Combo Jack. The Mic level has increased a bit. I can live with it. Thanks once again (y)
try this.
try this.
Thank you for all the efforts. After couple of hours, the earlier, last version is unable to accept keyboard input. I'll use the last version which i checked yesterday. When i'll more time, probably after Christmas, we can test it again. Thanks (y)
Hi @Mirone
Is the issue in AppleHDA patcher fixed?
@EliteMacx86 , try this versions and tell me if the microphone works with any of them.
Hi @Mirone
I hope you're good. Wishing you a very Happy New Year 2019
The v2 is randomly giving issues for the Keyboard thing. Unable to use the keyboard and it disables the Brightness, completely dark.
Hi @Mirone
Do you've any clue why the Microphone doesn't works on ALC255? Used patch from AppleHDA patcher.
GabyXB
