How to Enable Reset NVRAM Option in OpenCore
To reset NVRAM to clear the variables, you'll need to enable the Reset NVRAM option in OpenCore. To enable the Reset NVRAM option, follow the steps below.STEP 1: Determine the OpenCore version
STEP 2: Depending on your OpenCore version, download the appropriate OpenCore package. Only, if you haven't followed the basic EFI Creation guide.
STEP 3: Mount your ESP.
STEP 4: Copy the required Drivers along with the
ResetNvramEntry.efi from the X64/EFI/OC directory to your EFI/OC in the ESP. Only, if the .efi files doesn't exists in the Drivers directory.
STEP 5: Open your config.plist using any XML editor.
STEP 6: Add
ResetNvramEntry.efi entry in the UEFI>Drivers section of your config.plist. Ensure that the LoadEarly option is unchecked.
STEP 7: Save your config.plist
QUICK INFO:
When theHideAuxiliaryoption isEnabled, you need to press theSpace Bar Keyon your Keyboard to show all the other options in the picker.
See How to Reset NVRAM using OpenCore
GUIDE - How to Reset NVRAM [Clover/OpenCore]
How to Reset NVRAM [Clover/OpenCore] This guide describes how to reset NVRAM using Clover and OpenCore. By following this guide, you'll be able to reset NVRAM for Clover or OpenCore bootloader. A reset of NVRAM might be required in several cases to clear off the variables stored in the NVRAM. To...
elitemacx86.com
