0x00001111
- Apr 30, 2022
- EPC621D8A
- Intel Gold 6278c
- rx590
Subsystem ID is always coming after the Vendor ID.
Since you didn't follow exactly my guide I can't control your offset values.
Follow my Guide and post the related offsets completely here.
It is necessary that the subsystem ID is 000a, otherwise the Smalltree driver will not work with it, that's why you change your 0000 Sub ID on your X772 NIC to 000a.
Wait a second... Your Motherboard use a 1 Gbit NIC... not 10 Gbit.
I also know X772 NIC's which are 10 Gbit NICs....
1 Gbit NIC Driver would be this one but this will not work since the It doesn't work via SUB System ID. It will only recognize Small Tree branded Intel PRO/1000 cards...
There are other methods which could work but I have to try some stuff which is a bit complicated without the motherboard itself.
Where do you come from ? Europe ? USA ?
It does not work via SUB Sytem ID. The Small Tree kext never loaded.
Thx anyway.
@DSM2
