Need Help at building the correct EFI for ‎AMD Ryzen 7 5800H!!
JackSparrow47
HP Victus 16
AMD Ryzen 7 5800H
AMD Radeon Graphics(Integrated), NVIDIA 3050 Ti 4gb (Dedicated)
I am not able to reach atleast GUI Installation on my system....
I attached my final EFI which is generated after going through @EliteMacx86 youtube tutorial
I followed every step and used a MAC under vMware as shown in the tutorial
Since I used the OpenCore-Debug so I also attached the error getting at the end where everything freezes after error shows up
I am ok if my dedicated GPU is not supported but atleast integrated might work
I have Windows 11 Installed and wanted to dual boot MAC OS
For My BIOS :- Secure boot is disabled
My Laptop:-HP Victus 16
Its Specs:- AMD Ryzen 7 5800H
NVIDIA Geforce 3050TI 4gb(Dedicated)
  • EFI.zip
    EFI.zip
There is no good reason to install on this hardware as it is of no use. NVIDIA GTX 3050Ti isn't supported and neither integrated one is. You'll lack Graphics acceleration if you manage to install it.
Sir i am ok to the lack of graphic acceleration but atleast go through my attached EFI and error to help get it to GUI installation.....:cry::cry:
What purpose will it serve?
It serve my ego after overcoming this problem and thats what I want....
btw please do a voice reveal at least dude
  • Wow
Reactions: 42n00b
Whoa.
So, the configuration you have is not as per the guide. Although, AMD guide is on the way.
Reactions: 42n00b
Whoa.
I followed your old opencore AMD video and configuration is upto that video atleast , btw I overcomed that particular error just by replacing com.apple.recovery.boot files of catalina to monterey but this time error is different😢😢
You should wait for a while on the guide.
  • Sad
Reactions: JackSparrow47
mohthearrow
