Please help build an EFI file compatible with this specification
Abukasim
Asus TUF Z390 Plus Gaming Wi-Fi
Intel Core i7 8700k
MSI Radeon RX 580 8GB ARMOR
10.13.x
I tried to upgrade to Monterey, but the boot is very slow and the secondary disks are not showing
How to fix freezing problem while using Final Cut Pro X or Adobe Premiere Pro
specification:
Platform: Intel 8th Gen
Processor: Intel Core i7 8700k
Motherboard: Asus TUF Z390 Plus Gaming Wi-Fi
RAM: Kingston HyperX 2666 4x 16GB 2600Mhz
GPU: MSI Radeon RX 580 8GB ARMOR
SSD: Kingston M.2 2280 PCIe NVMe SSD 256 GB
Power Supply: Corsair 730
SMBIOS: iMac19,1
macOS: BigSur
OpenCore 0.7.9 RELEASE
specification:
SMBIOS: iMac19,1
macOS: BigSur
For a minimal set of EFI, use the guide below
Reactions: Abukasim
Thank you for your reply
How do I know if the system is working as intended or not
If you don't have the issues again which you listed.
Reactions: Abukasim
specification:
SMBIOS: iMac19,1
macOS: BigSur
try this i have same hardware only intel i5 9600k is diferent.but is coffe lake and is suported on my EFI /// .work on Ventura to
  • EFI. VENTURA FLO.zip
igor333333
