- Mar 28, 2022
- Dell XPS 13 9360 (i7-8550u)
- i7-8550u
- UHD620
Hi, I installed Monterey successfully on my Dell XPS 9360 (i7-8550u/UHD620/QHD Display). But now I've got a problem: almost always when I use my laptop on battery the laptop just dies, no power at all, and I cannot even turn it back on. I need to plug in the DC adapter to get it back on (USB-C does not work in this case). In the bios power events I can see the following error: "ASF2 Force OFF".
Also I have to mention that the problem occurs after login. If I unplug the adapter after login it works fine (I tested it using the maxium frequency test of Intel Power Gadget to draw power from the cpu.)
Bios Settings:
Bios Settings:
Sata AHCI, SMART reporting ON, [*]USB BOOT and USB External enabled, [*]Allow Dell Docks ON, [*]Thunderbolt Disabled (Security Level: No security), [*]USB Powershare ON, [*]Unobtrusive mode ON, UEFI Capsule update ON, [*]TPM OFF, [*]Computrace OFF [*]CPU XD ON, [*]OROM OFF, [*]Secure Boot OFF, [*]SGX OFF, [*]SpeedStep ON, [*]C states ON, [*]TurboBoost ON [*]Hyperthread ON, [*]Battery Charge max 80%, Fastboot Minimal, [*]VT ON, VT-D OFF, [*]Wireless Switch OFF, [*]Bios Downgrade ON [*]Undervolting CPU -100mV; GPU -30mV
