Antelope Orion Synergy core Thunderbolt 3
wicko
gigabyte z390 designare
Intel Core i9 9900K
Sapphire Pulse Radeon RX 580
10.15.x
Hi
I Have a working hackintosh using clover but it doesn't recognise my interface via thunderbolt 3.
I have copied your settings in the bios. I would be grateful for help with the following please?
-Please can you tell me where to find the downloads for the DMAR.aml and MaciASL files mentioned in the guide?.
-Can you please tell me how to how to 'Extract your native ACPI Tables?
-How do I edit the clover drop tables DMAR, DisableIoMapper etc?
Thanks
Before working on the Antelope Hardware, the first step should be to implement the TB including HotPlug, which will make the Antelope hardware.
It's already mentioned in the guide.
Refer to the guide below
Hi thanks for your help. I will have another look
Cheers
mclarke
