Problems with my Hackintosh
Here are following issues.
- ACPI is not patched.
- For USB, enable XHCIPortLimit quirk in Kernel.
I disabled XHCIPortLimit in config in Opencore. ACPI tried 2 patches of rehabman but didn't work
OK, But how do I use Asmedia's USB 3.0 port?
When you enable it, do you see the port info in Hackintool? If not, use GenericUSBXHCI.kext from Rehabman.
Ok, i will try. But in Hackintool my friend told me to show only Intel's USB and Asmedia's didn't show, is that correct?
No, that's wrong. If activated, all the USB Controllers will appear.
xmax114
