goodguy
 - Dec 11, 2021
 - Asus Proart Creator z490 10G
 - i9 10850K
 - iGPU Intel HD630
 - 10.13.x
 - iMac
Every couple of days, I loose Hotplug, I don't know why, so I think about flashing the Thunderbolt ChipIt could possibly work, with the use of Jumpering the TB header, as described in the TB installation guide. We managed to get EVGA Motherboard working, with a complete TB Hotplug function, where the Motherboard has no TB support and lacks TB Header too
Yes, but you need to check all the slot's path addresses for proper utilization. Confirm such with us before you buy a Card. Also, not sure why you prefer that way when your Motherboard is already equipped with a Thunderbolt 3 chip, probably, JHL7540 which can be flashed to a custom firmware. Instead of buying a PCIe Card and flashing a custom card, I suggest you go this way.
I've heard of flashing a budget Gigabyte Card, but flashing the Mainboard gets expensive if it goes wrong.
Questions:
If flashing the Thunderbolt Chip on the Mainboard, can I go back (reflash) to the original?
Is it possible to "brick" the Thunderbolt, if flashing goes sideways?
Does flashing render the Thunderbolt Menu in the BIOS obsolete?
How do I find the right Chip on the Mainboard?
