GUIDE How to Create OpenCore config.plist file for booting macOS on Intel Laptops
Someone was able to get a Rocket Lake (11th gen desktop) build going disabling the iGPU... So there's hope yet Tiger Lake (11th gen mobile) could work eventually too, albiet probably without iGPU acceleration.
I tried their EFI with an 11.4 beta USB on my Tiger Lake NUC, however it just bounces back to the bios boot menu; thinking maybe I need to try OpenCore Debug builds next; though I really don't have much clue as to what I'm doing :ROFLMAO:
EDIT: add link to the place where the guy did Rocket Lake build (it started as 10th-gen and then upgraded cpu)
Desktop and Laptops are entirely two different hardware. It can work on Laptops too with a spoofed CPU ID. But the Graphics acceleration is the main issue.
Never use someone's else EFI. It's always good to create one for yourself.
hi I have Asus vivobook
11 Gen tiger lake intel core i7
8 GB ram
ssd Nvme m.2 500 GB
there is no detail explanation about TIGER LAKE YOU SUPPORT Big Sur
8 GB ram
ssd Nvme m.2 500 GB
It's still not supported that's why not added into the list.
ok thanks this is why I am wondering where is explanation for tiger lake
Any prediction for when Tiger Lake might be supported? Thank you!
xmax114
