Hope the info is ok now. Thank
Sorry. I did send you a photo from IOreg and I thought was ok.
Kextcache output is still missing.
Firmware details are missing.
BIOS Settings for TB is missing.
Looks like the IOReg is different from the EFI you attached.
Hope now is ok
Hope now is ok
Try to reset NVRAM. The config.plist shows the injected SSDTs for TB. However, the IOReg has no sign of it.
Nvram resset no success.
If i restar comp everything disapear from pci related to thunderbolt.
Reset BIOS, setup BIOS again. Connect any TB Device to first port. Attach EFI+IOReg.
Ive reseting BIOS. It look the same as before.
mac300
