GUIDE How to Enable AMD Graphics in macOS [Clover/OpenCore]
An EliteMacx86 Exclusive Guide - This guide covers the implementation of supported AMD GPU on macOS. By following this guide, you'll be able to enable AMD Graphics on macOS using Clover or OpenCore Bootloader with full QE/CI.
Apple has been using a wide range of AMD Graphics Card for a long time. The good news is with the release of macOS version 10.12.6, the drivers for RX 470, RX 480, RX 570, and RX 580 are included. This means from macOS 10.12.6 and future macOS versions, we don’t need to perform any kext modifications to make AMD GPUs work in the build.
With such good support for AMD GPUs, it's quite easy to get AMD graphic cards working on macOS Sierra 10.12.6 and later which requires only a few steps. The sleep/wake function also works normally without any restarts or crashes. Also, you don't need to use any helper cards or IGPU.
Before macOS Sierra version 10.12.6, it was quite difficult to get any AMD Cards working as it involved several steps to get it working with the right framebuffers which were too difficult for any beginner/new users. With this, it had a few restrictions and required a helper/secondary or IGPU(Intel HD Graphics) for the hardware acceleration.
Now you can run AMD graphics card natively without the need of installing any Drivers like NVIDIA and extra configuration. With the release of macOS High Sierra, a wide range of AMD graphics cards has been added and has better support than macOS Sierra in terms of AMD GPUs.
This method is easy to roll back and works after the update. Before using this guide, we recommend you to perform a clean installation of macOS.
Following are the requirements for enabling AMD Graphics on macOS. Please ensure you meet the requirements before proceeding with this guide.
CPUmacOS compatible CPU. See CPU Compatibility for more information.
AVX2 is required for native support of AMD GPUs. See CPUs with no AVX2 support for more information.
GraphicsmacOS Compatible AMD GPU. See AMD Graphics Compatibility for more information.
KextsOriginal Graphics kexts in S/L/E
macOS VersionOS X Lion 10.7.5 and later
  • IOReg
For RX 6000 Series AMD NAVI GPU, see below:
For AMD APU, see below:
CPUs with no AVX2 support, see below:
Starting with macOS Ventura, you'll require a CPU with AVX2 instruction support. This means you need atleast Haswell CPU in Intel lineup. Due to lack of AVX2 support on CPUs prior than Haswell, the AMD Graphics drivers won't load. If your CPU is prior than Haswell, follow the guide linked below:
Enabling AMD Graphics in macOS
Following are the steps to enable AMD graphics on macOS:
The very first step is to set up BIOS to have the AMD GPU Enabled on your System. Follow the steps below to set up your BIOS for enabling AMD GPU.
1. On your target computer, boot to BIOS. Refer to your motherboard's user manual for the BIOS Key.
2. Adjust the following settings described below:
SettingsValueNotes
Initial PCIe Output DisplayPCIe/Auto/EnabledUse one of the values available, depending on your BIOS options.
This is usually present as VGA Priority on enterprise grade servers and workstations.
Intel Processor GraphicsDisabled/EnabledIf your processor has a compatible IGPU that is supported under macOS and you're using a compatible SMBIOS, then its recommended to set the IGPU to Enabled for the QuickSync feature.
This is usually present as Internal Graphics option in BIOS.
CSMDisabled
PCIE ROMUEFI/UEFI ROM onlyThis is usually present on enterprise grade servers and workstations and is available under PCIe/PCI/PnP Configuration option.
Above 4G DecodingEnabledIf you're using an enterprise grade servers and workstation, it is recommended to Disable this option and use npci flag instead.
Re-Size BARDisabled
Boot Mode SelectUEFI
  • The above settings are for Graphics only. See BIOS Settings for more information.
  • If your system does not have any of the above settings in BIOS, ignore such settings.
  • If your BIOS has Legacy Option ROMs, set it to UEFI/UEFI Only.
3. Save & Exit Setup
STEP 2: Cleanup old work
Once you have set up the BIOS, the next step is to remove the kexts, injections, and ACPI renames that can interfere with the Graphics implementation. To remove such, follow the steps below:
Kexts Removal
If you're using any of these kexts listed below, it is recommended to remove them. See notes below.
1. Mount your ESP.
2. Remove the following kexts:
  • IntelGraphicsFixup.kext
  • NvidiaGraphicsFixup.kext
  • CoreDisplayFixup.kext
  • Shiki.kext
  • IntelGraphicsDVMTFixup.kext
  • AzulPatcher4600.kext
  • AppleBacklightFixup.kext,
  • FakePCIID_Intel_HD_Graphics.kext
  • FakePCIID_Intel_HDMI_Audio.kext
  • FakePCIID.kext
  • If you're using OpenCore, you'll also need to remove the kext entries from your kernel section in your config.plist
  • For macOS Catalina and prior, make sure these kexts don't exist in Library/Extensions or System/Library/Extensions.
  • Do not remove FakePCIID.kext if you're using any other FakePCIID plugins.
Clover Properties and Injections
If you're using Clover, you need to disable Clover properties and injections.
1. Mount your ESP.
2. Open your config.plist using any XML editor and disable and/or remove the following from their respective sections as described below:
Disable DSDT Fixes
The DSDT fixes can be disabled in Acpi>Fixes section.
  • AddHDMI
  • FixDisplay
  • FixIntelGfx
  • AddIMEI
  • FixHDA
  • AddPNLF
Remove Fake IDs
The Fake IDs can be disabled in the Devices>Fake ID section.
  • ATI
  • IntelGFX
  • NVidia
  • IMEI
Disable injection properties
The injection properties can be disabled in the Devices>Properties section.
  • Inject
  • UseIntelHDMI
  • HDMIInjection
  • SetIntelBacklight
  • SetIntelMaxBacklight
Disable Graphics Injection
The Graphics injection can be disabled in the Graphics section
  • ATI
  • Intel
  • NVidia
Remove ig-platform-id
The ig-platform-id can be removed in the Graphics section
ACPI Renames
If you're using any ACPI renames, you'll need to disable or delete the ACPI renames as these can conflict with WhateverGreen's automatic renames.
1. Mount your ESP.
2. Open your config.plist using any XML editor and remove the following ACPI renames. For Clover, it's in Acpi>DSDT>Patches section, and for OpenCore, it's under ACPI>Patch section:
  • GFX0 to IGPU
  • PEGP to GFX0
  • HECI to IMEI
  • MEI to IMEI
  • HDAS to HDEF
  • B0D3 to HDAU
STEP 3: Adding Required Kexts
The next step is to add the required kexts to enable AMD Graphics. WhateverGreen doesn't work standalone. WhateverGreen and Lilu are needed together to work in conjunction in order to enable AMD Graphics and prevent any errors.
1. Download WhateverGreen and Lilu from the downloads section of this forum.
For Clover:
If you're using Clover, copy both the kexts to EFI/Clover/Kext/Others
For OpenCore:
If you're using OpenCore, copy both the kexts to EFI/OC/Kexts.
Open your config.plist using any XML editor and add Lilu.kext, and WhateverGreen.kext entries in the Kernel>Add section of your config.plist:
  • If the kext is already present in the directory, replace them with a new version.
  • Do not use WhateverGreen.kext.dSYM, WhateverName.app and Lilu.kext.dSYM.
STEP 4: Add Required Boot Args
Once you have added the kexts, the next step is to add the required boot args. To add the boot args, follow the steps below:
For Clover:
Assuming the config.plist is still open, add agdpmod=pikera to the Boot Arguments under the Boot>Argument section of your config.plist.
For OpenCore:
Assuming the config.plist is still open, add agdpmod=pikera to the boot-args key under the 7C436110-AB2A-4BBB-A880-FE41995C9F82 UUID list in the NVRAM section of your config.plist.
This step is only required for AMD 5000 and 6000 series GPUs.
See Fixing Blackscreen if you're getting blackscreen on macOS Tahoe.
STEP 4: Restart your System
Verifying your Card
Look for the information of your card under About this Mac and verify the VRAM. For more information about your Card, navigate to System Information and navigate to Graphics/Displays Tab.
NOTE:
  • If you get a black screen, make sure to update your BIOS and switch from Legacy to UEFI boot mode.
Sample Attachment
The AMD RX580 from Sapphire and ASUS are used as examples in this guide.
Credits :
vit9696
Reactions: imran.dim
谢谢版主66666
Is there a way I can use this method to make Radeon Pro WX 2100 to work on MacOS Big Sur?
Unfortunately, not supported. You could try OpenCore Legacy Patcher for more info.
An EliteMacx86 Exclusive Guide - This guide covers implementation of supported AMD GPU on macOS.
Apple has been using a wide range of AMD Graphics Card from a long time. The good news is with the release of macOS version 10.12.6, will include the drivers for RX 470, RX 480, RX 570, and RX 580. This means from macOS 10.12.6 and future macOS version, we don’t need to perform any kext modifications to make AMD GPUs working in the build.
With such a good support for AMD GPUs, it's quite easy to get AMD graphics card working on macOS Sierra 10.12.6 and later which requires only few steps. The sleep/wake function also works normally without any restarts or crashes. Also you don't need to use any helper cards or IGPU.
Before macOS Sierra version 10.12.6, it was quite difficult to get any AMD Cards working as it involved several steps to get it working with right framebuffers which was too difficult for any beginner/new users. With this, it had a few restriction and required helper/secondary or IGPU(Intel HD Graphics) for the hardware acceleration.
Now you can run AMD graphics card natively without need of installing any Drivers like NVIDIA and extra configuration. With the release of macOS High Sierra, a wide range of AMD graphics cards has been added and has more better support than macOS Sierra in terms of AMD GPUs.
This method is easy to roll-back and works after update. Before using this guide, we recommend you to perform a clean installation of macOS.
GraphicsSupported AMD GPU
KextsOriginal Graphics kexts in S/L/E.
Compatibility
For more information on GPU compatibility, refer to the thread linked below.
BIOS Settings
The BIOS settings has been provided in a separate thread. For more information on BIOS settings, refer to the thread linked below.
Adding required kexts
The next step is to download the required kexts to enable AMD Graphics. WhateverGreen doesn't works alone. WhateverGreen and Lilu is needed together to work with conjunction in order to enable the AMD Graphics and preventing any errors.
For Clover:
For OpenCore:
If you're using OpenCore, copy both the kexts to EFI/OC/Kexts. You'll also need to add the kexts entries in Kernel section of your config.plist
  • Download only RELEASE.zip file.
Restarting your System
Verifying your Card
Look for the information of your card under About this Mac and verify the VRAM. For more information of your Card, navigate to System Information and navigate to Graphics/Displays Tab.
  • If your BIOS has CSM option, disable it.
  • If your BIOS has PCI ROM Priority, set it to UEFI/UEFI ROM.
  • If you're using a NAVI GPU, you'll need to add "agdpmod=pikera" in boot arg.
Sample Attachment
The AMD RX580 from Sapphire and ASUS are used as the example in this guide.
Credits :
vit9696
Hello
Does Catalina 10.15.7 support Radeon R5 m430 ?
If yes how can I enable it?
Hello
Mobile GPUs are not supported under Switchable Graphics configuration.
Compatibility
BIOS Settings
For Clover:
For OpenCore:
Verifying your Card
Sample Attachment
Credits :
vit9696
Hello
Succes!I I made it work with intel graphics 520 but the keyboard is not fully supported . for example i cant change the language with ctrl + space!! the command button is the alt. Is there a solution for it?
Hello
You can map the keyboard manually. To do that, you can use Karabiner Elements.
oneinchashh
