[Guide] Dell Vostro15 3558 - Intel Core i3 - 4005U - 4GB RAM - Intel HD Graphics 4400
Striker
Moderator
Donator
Gigabyte Z790 AERO G
Intel Core i9 13700K
Sapphire TOXIC AMD Radeon RX 6900 XT Extreme Edition
  2. Mac mini
  3. MacBook Air
  4. MacBook Pro
Complete installation guide for installing macOS Mojave 10.14 (18A391) on Dell Vostro15 3558
Specifications :
Laptop : Dell Vostro15 3558
CPU: Intel Core i3 - 4005U
RAM: 4 GB 1600MHz
IGPU: Intel HD Graphics 4400
SSD: Transcend TS128GSSD370
Audio: Realtek ALC255
Display: 15.6" (1366x768)
Wireless/Bluetooth: Intel Dual Band Wireless-AC 3160 (Unsupported)
Trackpad: Dell DLLC6C0
Camera: Realtek UVC Camera
Ports: 1 x USB 3.0 | 2 x USB 2.0 | 1 x VGA | 1 x SD Card slot | 1 x 3.5mm audio combo jack I 1 x LAN Port
Summary :
What's works?
Audio (Internal Mic + Combo Jack)
Keyboard
Trackpad (With Gestures)
Brightness
Brightness Hotkeys
Battery Meter
Power Management
iMessage
FaceTime
iCloud
USB 2.0, 3.0Ports
Not working
Only WiFi and Bluetooth (Unsupported), replacement needed
Bootable Media Creation
STEP 1
To create Bootable USB for installation
Insert USB Flash Drive and open Disk Utility
Select USB Flash Drive and Erase it with following parameters
Format
: OS X Extended (Journaled)
Scheme
: GUID Partition Map
Launch Terminal
Copy and paste the following sudo command in terminal
Enter Password, when it asks
Press (Y) for confirmation of the proceeding process and press Enter key
Close Terminal after execution of the process
STEP 2
Download Clover EFI Bootloader from the Forum Downloads Section
Run Clover EFI bootloader installer package
In Clover Bootloader click on Change Install Location and select installation Drive i.e Install macOS Mojave.
Click on Customize and configure the following settings.
Install Clover for UEFI booting only
Install Clover in the ESP
Themes: Select any
Drivers64UEFI: AptioMemoryFix-64 , ApsDriverLoader-64 and
Confirm the above options and click on Install. Enter Password when it asks.
Click on Close after execution of the process
STEP 3 :
Now you'll have to place the necessary Files, Kexts & Config.plist
Navigate to: EFI/CLOVER
Replace Config.plist with default one
Navigate to: EFI/CLOVER/drivers64UEFI/
Place HFSPlus.efi : https://github.com/JrCs/CloverGrowerPro/raw/master/Files/HFSPlus/X64/HFSPlus.efi
After that
Navigate to: EFI/CLOVER/kexts/
Place following kexts in the folder
FakeSMC.kext: https://github.com/RehabMan/OS-X-FakeSMC-kozlek
VoodooPS2Controller.kext: https://github.com/RehabMan/OS-X-Voodoo-PS2-Controller
USBInjectAll.kext: https://github.com/RehabMan/OS-X-USB-Inject-All
Lilu.kext: https://github.com/acidanthera/Lilu
WhateverGreen.kext: https://github.com/acidanthera/WhateverGreen
Now, everything is done USB is fully prepared for installation
UEFI settings
Set Network Stack to Disabled.
Set Boot Sequence to UEFI
Set Secure Boot to Disabled.
Set SATA Mode to AHCI.
Set VT-d Option to Disable
Set Intel Virtualization Technology to Enabled
Set Fast Boot to Disabled
Booting the Installer using USB
After preparing installation USB
Plug the USB flash drive in USB 2.0 port and boot to boot menu
Select USB with the UEFI prefix and press enter to boot
Use following boot args :
-v
-nv_disable=1
Select Boot macOS Install from Install macOS Mojave and press enter to boot
When at installation screen
select preferred language and continue
Select Disk Utility and continue
click on View and select Show all Devices
select Hard Drive or SSD on which you want to install macOS
Select the Drive and click on Erase button
Name : Macintosh HD* (You can rename it later on)
Format
: APFS
Scheme : GUID Partition Map
After execution of the process Close Disk Utility
Select Install macOS and continue with the options.
Now select Macintosh HD* and click on Install.
When the laptop restarts, select Boot macOS Install from Macintosh HD or (Drive name) and press enter
After installation, boot it using USB, but this time select Macintosh HD or (Drive name) and press enter
When you're at the welcome screen, continue with the basics options such as Keyboard setup, Network, Computer Account and Privacy settings
Post Installation
Boot from System Drive
Mount the EFI Partitions of BOTH USB as well as Hard Drive/SSD
Open EFI Partition of Hard Drive
Select EFI folder and then move to Trash
Open EFI Partition of USB
Copy the EFI folder to EFI Partition of Hard Drive.
Intel HD Graphics 4400 is supported and will run in full QE/CI OOTB
Network
The Laptop uses Realtek RTL 8111 Ethernet Chipset. Install Realtek RTL8111.pkg
DSDT and SSDT Patching
For the DSDT and SSDT patching, follow the DSDT and SSDT patching guide here: https://www.elitemacx86.com/threads/guide-how-to-patch-laptop-dsdt-and-ssdts.178/
DSDT
Rename _DSM to _XDSM
Layout id = 3(0x03)
Rename GFX0 to IGPU
Fix _WAK Arg0 v2
HPET Fix
SMBUS Fix
IRQ Fix
RTC Fix
OS Check Fix
Fix Mutex with non-zero SyncLevel
7 Series/8 Series USB
Dell Vostro15 xx
The DSDT will have have three errors, to fix it replace the "code"
Replace this code:
If (LEqual (PM6H, One))
                    CreateBitField (BUF0, \_SB.PCI0._Y0C._RW, ECRW)  // _RW_: Read-Write Status
                    Store (Zero, ECRW (If (PM0H)
                                CreateDWordField (BUF0, \_SB.PCI0._Y0D._LEN, F0LN)  // _LEN: Length
                                Store (Zero, F0LN)
with this one :
                    Store (Zero, ECRW)
If (PM0H)
                                Store (Zero, F0LN)
SSDT
Rename GFX0 to IGPU
Cleanup/Fix Errors (SSDT)
Remove _PSS placeholders
The SSDT (SSDT-1-Cpu0Ist) will have eight errors, to fix it patch it with "Remove_PSS placeholders"
Place all the patches DSDT and SSDTs to : EFI/ACPI/Patched.
Open config.plist
Check "Drop OEM"
Under Sorted Order, list all of DSDT and SSDTs with the suffix i.e. .aml
Audio
The Laptop uses a Realtek ALC255 Audio Codec
To patch AppleHDA for this Audio Codec follow the guide here: https://www.elitemacx86.com/threads/a-beginners-guide-how-to-patch-applehda-for-laptops.184/
Install the kext to S/L/E
Open config.plist
Under Acpi patches, add the following patch
Comment: Rename HDAS to HDEF
Find* [HEX]: 48444153
Replace [HEX]: 48444546
Use layout ID =3
Check "ResetHDA"
For resolving the audio distortion in Headphones, follow the guide here: https://www.elitemacx86.com/threads/fix-audio-distortion-when-using-headphones-on-laptops.185/
USB Ports
For USB Ports install FakePCIID_XHCIMux.kext & FakePCIID.kext
Link to the Downloads : https://github.com/RehabMan/OS-X-Fake-PCI-ID/blob/master/FakePCIID/FakePCIID_XHCIMux.h
Do not download the project files. The pre-built binaries/downloads are available in the README.md section. Make sure you read it carefully.
Download the latest version for better support.
Use the kext from Release folder and Release.zip file.
Add USB port limit patch
Mount EFI Partition
Open config.plist file using Clover Configurator
Navigate to kernel and kext patches tab and add the following patch in config.plist.
Find* [HEX]: 83FB0F0F 83030500 0
Replace* [HEX]: 83FB0F90 90909090 90
Comment: USB 10.14.x by PMHeart
MatchOS: 10.14.x
Save config.plist file
Trackpad
The trackpad works OOTB. To implement Gestures for Trackpad, follow the guide here: https://www.elitemacx86.com/threads/guide-how-to-fix-trackpads-on-laptops-including-gestures.293/
Battery Meter
Install ACPIBatteryManager kext.
Power Management
The CPU power management works OOTB. For more information, read here: https://www.elitemacx86.com/threads/guide-enable-native-power-management-on-laptops.187/
Restart Laptop for implementing the changes
App Store
iMessage
FaceTime
iCloud
To activate App Store iMessage FaceTime & iCloud, follow the instructions below :
Mount EFI partition
Open config.plist
Navigate to SMBIOS Tab
Generate a new SMBIOS for "MacBook Pro11,1"
Save config.plist
Restart laptop
Login into App Store, iMessage, FaceTime and iCloud.
By following the above Guide, A full working macOS Mojave on Dell Vostro15 3558 can be installed
Credits:
A special Thanks to @EliteMacx86 for the wonderful guides which is super easy to follow.
RehabMan for his great work.
Pokenguyen and macgihan for the DSDT edits.
Reactions: Cyberdevs
ilikeeatingpeeandpoo
