Uploading files via wifi leads to panic
neosoftware
x79
e5 2697v2
rx 580
10.13.x
There is a computer (huanan x79) with BCM94360CD module via pci-e adapter and bigsur 11.4 system installed.
Everything works fine, stern tests pass without problems. But there is one problem associated with uploading big data through the wifi module (when uploading files to the site, when you run the speedtest during the upload test, the first download test will go off with a bang and show about 80 mb / s) in this case, the computer does not turn off completely and the image disappears, I tried to leave the music working at this time and it played from the speakers for about a minute, but there was no image. Before that, the Catalalina system was melting and there were no problems.
Initially I set up the system without cakes
AirportBrcmFixup
BrcmBluetoothInjector
BrcmFirmwareData
BrcmPatchRAM3
but even with the addition of these kexts, nothing has changed
If during the screen shutdown you do not do anything, then after some time the computer will reboot and when the system boots up, the report shows the following information:
panic(cpu 2 caller 0xffffff801bbf9a25): userspace watchdog timeout: no successful checkins from com.apple.WindowServer in 120 seconds
service: com.apple.logd, total successful checkins since load (270 seconds ago): 28, last successful checkin: 0 seconds ago
service: com.apple.WindowServer, total successful checkins since load (240 seconds ago): 12, last successful checkin: 120 seconds ago
Backtrace (CPU 2), Frame : Return Address
0xffffffc1212f3670 : 0xffffff801888e0dd
0xffffffc1212f36c0 : 0xffffff80189d4f33
0xffffffc1212f3700 : 0xffffff80189c552a
0xffffffc1212f3750 : 0xffffff8018832a2f
0xffffffc1212f3770 : 0xffffff801888d8fd
0xffffffc1212f3890 : 0xffffff801888dbf3
0xffffffc1212f3900 : 0xffffff801909d884
0xffffffc1212f3970 : 0xffffff801bbf9a25
0xffffffc1212f3980 : 0xffffff801bbf9660
0xffffffc1212f39a0 : 0xffffff801901e13e
0xffffffc1212f39f0 : 0xffffff801bbf8a34
0xffffffc1212f3b20 : 0xffffff801902837b
0xffffffc1212f3c80 : 0xffffff8018980961
0xffffffc1212f3d90 : 0xffffff801889375d
0xffffffc1212f3e00 : 0xffffff8018869cf5
0xffffffc1212f3e60 : 0xffffff8018881312
0xffffffc1212f3ef0 : 0xffffff80189a982d
0xffffffc1212f3fa0 : 0xffffff8018833216
Kernel Extensions in backtrace:
com.apple.driver.watchdog(1.0)[C29AFC04-7113-39AA-80DF-00F4DDAD0F46]@0xffffff801bbf7000->0xffffff801bbf9fff
Process name corresponding to current thread: watchdogd
Boot args: npci=0x2000 -v debug=0x100 darkwake=0
Mac OS version:
20F71
Kernel version:
Darwin Kernel Version 20.5.0: Sat May 8 05:10:33 PDT 2021; root:xnu-7195.121.3~9/RELEASE_X86_64
Kernel UUID: 52A1E876-863E-38E3-AC80-09BBAB13B752
KernelCache slide: 0x0000000018600000
KernelCache base: 0xffffff8018800000
Kernel slide: 0x0000000018610000
Kernel text base: 0xffffff8018810000
__HIB text base: 0xffffff8018700000
System model name: iMacPro1,1 (Mac-7BA5B2D9E42DDD94)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 294220426334
Last Sleep: absolute base_tsc base_nano
Uptime : 0x0000004480e77866
Sleep : 0x0000000000000000 0x0000000000000000 0x0000000000000000
Wake : 0x0000000000000000 0x000000162d496c5a 0x0000000000000000
tell me how to fix wifi so that the computer does not turn off (if you use a cable connection, then there are no problems, but where this computer is located there is no physical possibility to stretch the cable, so wifi is necessary)
Could you explain it more clearly?
As per your panic log, the panic is due to Watchdog driver. You can simply disable the Watchdog in your config.plist.
You should consider attaching the PR files.
in cataline via wifi Download and upload files work.
In bigsur, only download works via wifi, upload turns off the computer.
Watchdog disabled in the opencore configuration, now the black screen turns off, freezes, and it does not restart
opencore config files?
Which black screen?
Incomplete PR files attached.
ilikeeatingpeeandpoo
