Updating macOS High Sierra
manevdusko
Asus x552cl
Intel Core i3-3217U
NVIDIA GEFORCE 710m
12.x
  1. Clover (Legacy)
Hi friends
I have a problem with updating my hackintosh from 10.13.5 to 10.13.6.
I downloaded macOS 10.13.6 from app store and tryed to install it but after restart there is a problem: ”macOS could not be installed on your computer”. My computer is successful installed and working on macOS High Sierra 10.13.5.
If you have any solutions please help me or if you know other ways for updating it will be helpful.
Thank you
Hi friends
Thank you
Your profile indicates you're using a Laptop. Is that correct?
The error, ”macOS could not be installed on your computer”, you're getting because you're running a incompatible SMBIOS. Also, your profile shows you're using Clover Legacy. As per FAQ, i suggest you to use Clover UEFI. Read here: https://www.elitemacx86.com/threads/faq-read-first-questions-related-to-laptop.175/
@Cyberdevs has written a very well guide. Read here: https://www.elitemacx86.com/threads...rra-or-macos-high-sierra-to-macos-mojave.247/
Make sure that you set a appropriate SMBIOS for your Laptop. You should be good to go!
Thanks for helping
Hi friends
Thank you
Have you downloaded the Full installer for High Sierra or tried to update 10.13.5 to 10.13.6 via App Store's update section?
Atlanxg
