Dell Latitude 7400 | Intel Core i7-8665U | 32GB RAM | Intel UHD Graphics 620
This is a complete installation guide to install macOS Big Sur 11.2.3 on Dell Latitude 7400. The purpose of this guide is to provide a step-by-step guide to install Big Sur using OpenCore UEFI.
Specifications
ComponentModel Number
TabletLenovo Ideapad S540-15IWL
ProcessorIntel Core i5-8265U
RAM8GB 1866MHz
GraphicsIntel UHD Graphics 620
SSDSamsung 512GB NVMe SSD
AudioRealtek ALC257
Display15.6” FHD (1920x1080) IPS, antiglare, 300 nits, 72% NTSC
Wireless/BluetoothReplaced with Broadcom BCM94352Z, NGFF, M.2, A+E Key Type
WebCamSunplusIT Integrated Camera
FingerprintGoodixFingerPrint
Ports1 x DC Power Input | 1 x HDMI | 2 x USB 3.0 | 1 x USB Type-C Gen2 | 1 x 3.5mm audio combo jack | 1 x SD Card slot
Summary
FeaturesStatus
GraphicsYES
Built-in AudioYES
BrightnessYES
Brightness HotKeysYES
FingerprintNOT SUPPORTED
WebCamYES
Battery meterYES
Card ReaderYES
EthernetYES
WiFi/BTYES
AirDropYES
HandoffYES
Apple Watch UnlockYES
Power ManagementYES
App StoreYES
iMessageYES
FaceTimeYES
iCloudYES
USB 2.0, and USB 3.0 Ports and Type-CYES
Not working
  • Fingerprint is unsupported and it doesn't works.
  • There is a known issue with Samsung PM981 series NVMe. The SSD was replaced with Samsung 970 EVO Plus.
Bootable Media Creation
2. Plug USB to your system.
4. Close Disk Utility.
5. Open Terminal and type:
6. Enter your password
  • At this point, the bootable USB can be only used to boot Mac only. In order to boot the computer using the USB, follow the steps below.
Preparing OpenCore Bootloader
DirectoriesDescription
DocsContains documentation, change log, a sample config.plist, and ACPI Samples for OpenCore.
IA32Contains OpenCore EFI, 32-bit OpenCore Boot Loader.
UtilitiesContains several utilities.
X64Contains OpenCore EFI, 64-bit OpenCore Boot Loader.
Adding Required SSDTs
SSDT NameNotes
SSDT-EC-USBX
  • This SSDT fixes EC and USB Power.
  • This SSDT is required for proper USB Power.
SSDT-AWAC
  • This SSDT serves 300 series RTC patch.
  • This SSDT can also fix stuck at afps_module_start error while booting the installer.
SSDT-PLUG
  • This SSDT enables Power Management function.
  • This SSDT is required for a proper CPU and GPU Power Management.
SSDT-PNLFCFL
  • This SSD enables PNLF attaching to display.
  • This SSDT is required for Brightness function.
Adding Required Drivers
Driver NameRequiredNotes
OpenRuntime.efiYES
  • Runtime driver including several other drivers merged such as ApfsDriverLoader.
  • OpenRuntime.efi is a replacement for AptioMemoryFix.efi driver.
OpenHfsPlus.efiYES
  • Provides reading of HFS+ Volumes/drives in OpenCore Boot Picker.
OpenCanopy.efiOptional
  • Provides GUI functionality for OpenCore Boot screen.
  • This driver is required if you need GUI or theme for OpenCore.
AudioDxe.efiOptional
  • Provides Boot Chime support.
  • Only required if you want to use Boot Chime
3. From the EFI/OC directory, just keep the above drivers and delete rest of the drivers.
  • All the drivers can be found at: X64/EFI/OC/Drivers
Adding Required Kexts
Kext NameRequiredNotes
LiluYES
  • Provides arbitrary patching.
VirtualSMCYES
  • Emulates Apple hardware. VirtualSMC is a successor of FakeSMC.
  • This kext requires "Lilu.kext" to function.
WhateverGreenYES
  • Provides GPU patching on macOS.
AppleALCYES
  • Provides Audio support on macOS.
SMCBatteryManager.kextYES
  • Enables Battery Meter on macOS
AirportBrcmFixup.kextYES
  • Enables Broadcom WiFi on macOS
BrcmBluetoothInjector.kextYES
  • Enables Broadcom Bluetooth on macOS
BrcmFirmwareData.kextYES
  • Broadcom Firmware Injector for macOS
BrcmPatchRAM3.kextYES
  • Enables PatchRAM updates on macOS
  • This kext requires "BrcmBluetoothInjector.kext" to function.
USBInjectAllYES
  • Enables USB ports for mapping USB ports further.
  • It's advised to map the USB ports during the post-install for a better USB speed, improved sleep/wake and hotplug.
Sinetek-rtsx.kextYES
  • Enables Realtek SD Card Reader
VoodooI2C.kextYES
  • Enables I2C Controller Support
VoodooI2CHID.kextYES
  • Enables I2C Touchpad support on macOS
VoodooPS2Controller.kextYES
  • Enables PS2K Keyboard support on macOS.
1. Download the above kexts.
Notes
  • Do not download the project files. The pre-built binaries/downloads are available in the README.md section. Make sure you read it carefully.
  • Use the kext from RELEASE folder and RELEASE.zip file.
  • Do not place unnecessary kexts here. It might prevent booting the installer.
  • Only use basic kexts which is required to boot off the installer. You can install the rest required kexts at the time of post-installation.
  • The VirtualSMC package includes Battery and Sensors plugins (SMCBatteryManager.kext, SMCDellSensors.kext, SMCLightSensor.kext, SMCProcessor.kext, and SMCSuperIO.kext). You do not need these kexts for booting the installer.
ACPI>Add
SSDT NameNotes
SSDT-EC-USBX
SSDT-AWAC
SSDT-PLUG
SSDT-PNLFCFL
ACPI>Patch
Table Signature*FindReplaceCommentEnabledNotes
DSDT4746583049475055Rename GFX0 to IGPU (Graphics)NO
  • Renames GFX0 to IGPU for a better power management.
  • This rename is required for implementing IGPU Power Management.
DSDT48454349494D4549Rename HECI to IMEI (PAVP)*YES
  • Renames HECI to IMEI for PAVP services.
  • This rename is required for implementing PAVP services.
  • This rename fixes iTunes/App Store Content Access problems and also enables Content playback.
DSDT4D45495F494D4549Rename MEI to IMEI (PAVP)*YES
  • Renames MEI to IMEI for PAVP services.
DSDT4844415348444546Rename HDAS to HDEF (Audio)YES
  • Renames HDAS to HDEF for Audio.
  • This rename is required for implementing Audio Function.
Booter>Quirks
Notes:
  • *Requires both renames for full function.
  • GFX0 to IGPU rename must be enabled after ACPI patching.
Booter>Quirks
QuirksValueNotes
AvoidRunTimeDefragYES
  • Fixes certain UEFI runtime services such as date time, NVRAM, power control, etc.
EnableSafeModeSlideYES
  • Patch bootloader to have KASLR enabled in safe mode.
  • This quirk requires ProvideCustomSlide to be enabled.
EnableWriteUnprotectorYES
  • Allows write access to UEFI runtime services code.
ProvideCustomSlideYES
  • Provide custom KASLR slide on low memory.
  • This option forces macOS to use a pseudo random value among the available ones.
SetupVirtualMapYES
  • Setup virtual memory at SetVirtualAddresses.
  • Fixes several virtual address issues and tends to fix early Kernel Panics.
SyncRuntimePermissionsYES
  • Update memory permissions for runtime environment.
  • The need for this quirk is indicated by early boot failures. Only firmware released after 2017 is typically affected.
Note:
  • The values which have been not discussed above, that will remain disabled.
DeviceProperties
This section is used for adding device properties. This includes PCI Devices information such as Graphics, Audio, WiFi, Ethernet and other controllers. The following changes are needed.
DevicesKeyValueTypeNotes
PciRoot(0x0)/Pci(0x2,0x0)AAPL,ig-platform-id0900A53EDATA
  • Enables IGPU Graphics acceleration and support.
device-idA53E0000DATA
  • Sets Device ID for Whiskey Lake CPUs
framebuffer-con1-busid01000000DATA
framebuffer-con1-enable01000000DATA
  • Enables framebuffer connector 1.
framebuffer-con1-type00080000DATA
  • Sets framebuffer connector 1 type as HDMI
framebuffer-con2-enable01000000DATA
framebuffer-con2-indexFFFFFFFFDATA
framebuffer-con1-enable1NUMBER
framebuffer-fbmem
00009000
DATA
  • Specifies framebuffer memory size.
  • This is a memory which is reserved for the framebuffer.
  • Sets framebuffer memory size to 9MB
framebuffer-patch1-enable1NUMBER
  • Enables framebuffer patching.
framebuffer-stolenmem00003001DATA
  • Specifies stolenmem.
  • This is a memory which is reserved for the IGPU.
  • Prevents kernel panic due to less DVMT size set in BIOS/UEFI.
  • Sets framebuffer stolenmem size to 19MB
hda-gfxonboard-1STRING
  • Sets hda-gfx to onboard-1 on IGPU.
  • This property provides HDMI/DP function and can also fix crash issue when Hot plugging.
PciRoot(0)/Pci(0x1f,3)hda-gfxonboard-1STRING
  • Sets hda-gfx to onboard-1 on HDEF.
layout-id30NUMBER
  • Sets Layout ID for your Audio Codec.
no-controller-patch1NUMBER
Kernel>Add
ArchBundlePath*ExecutablePathPlistPathEnabledNotes
AnyLilu.kext**Contents/MacOS/LiluContents/Info.plistYES
AnyVirtualSMC.kext**Contents/MacOS/VirtualSMCContents/Info.plistYES
  • VirtualSMC is a successor of FakeSMC.
AnyWhateverGreen.kext**Contents/MacOS/WhateverGreenContents/Info.plistYES
AnyAppleALC.kext**Contents/MacOS/AppleALCContents/Info.plistYES
  • Enables onboard/built-in Audio.
AnyAppleBacklightFixup.kext**Contents/MacOS/AppleBacklightFixupContents/Info.plistNO
  • Enables Backlight Slider in System Preferences>Displays
AnySMCBatteryManager.kextContents/MacOS/SMCBatteryManagerContents/Info.plistNO
AnyAirportBrcmFixup.kextContents/MacOS/AirportBrcmFixupContents/Info.plistYES
AnyAirportBrcmFixup.kext/Contents/PlugIns/AirPortBrcmNIC_Injector.kextContents/Info.plistYES
AnyBrcmBluetoothInjector.kextContents/Info.plistYES
AnyBrcmFirmwareData.kextContents/MacOS/BrcmFirmwareDataContents/Info.plistYES
AnyBrcmPatchRAM3.kextContents/MacOS/BrcmPatchRAM3Contents/Info.plistYES
AnyUSBInjectAll.kext**Contents/MacOS/USBInjectAllContents/Info.plistYES
  • Enables USB ports.
  • It's advised to map the USB ports during the post-install for a better USB speed, improved and sleep/wake.
AnySinetek-rtsx.kext**Contents/MacOS/Sinetek-rtsxContents/Info.plistNO
  • Enables Realtek RTL 8111/8168 Family onboard Ethernet Controller.
AnyVoodooI2C.kext/Contents/PlugIns/VoodooGPIO.kextContents/MacOS/VoodooGPIOContents/Info.plistNO
AnyVoodooI2C.kext/Contents/PlugIns/VoodooI2CServices.kextContents/MacOS/VoodooI2CServicesContents/Info.plistNO
AnyVoodooI2C.kextContents/MacOS/VoodooI2CContents/Info.plistNO
AnyVoodooI2C.kext/Contents/PlugIns/VoodooInput.kextContents/MacOS/VoodooInputContents/Info.plistNO
AnyVoodooI2CHID.kextContents/MacOS/VoodooI2CHIDContents/Info.plistNO
AnyVoodooPS2Controller.kextContents/MacOS/VoodooPS2ControllerContents/Info.plistYES
AnyVoodooPS2Controller.kext/Contents/PlugIns/VoodooInput.kextContents/MacOS/VoodooInputContents/Info.plistYESDelete this entry after postinstallation.
AnyVoodooPS2Controller.kext/Contents/PlugIns/VoodooPS2Keyboard.kextContents/MacOS/VoodooPS2KeyboardContents/Info.plistYES
AnyVoodooPS2Controller.kext/Contents/PlugIns/VoodooPS2Mouse.kextContents/MacOS/VoodooPS2MouseContents/Info.plistYES
AnyVoodooPS2Controller.kext/Contents/PlugIns/VoodooPS2Trackpad.kextContents/MacOS/VoodooPS2TrackpadContents/Info.plistYES
Notes:
  • All the plugins must load after loading it's dependencies otherwise the kext will no longer function even when loaded in OS X/macOS.
  • The mandatory kexts must be loaded in sorted order as shown in the above table.
  • *Indicates BundlePath i.e. Name of the Kext
  • **Indicates mandatory kexts.
  • All the added kexts must exists in the EFI/OC/Kexts directory.
  • The options which have been not discussed above, that will remain untouched.
Kernel>Scheme
OptionsValueNotes
FuzzyMatchYES
  • Enables checksum ignore with kernel cache instead of using latest cache available.
  • This setting allows matching the latest kernel cache with a suitable architecture when the kernel cache without suffix is unavailable, improving macOS 10.6 boot performance on several platforms.
KernelArchAuto
  • Determines Kernel Architecture.
KernelCacheAuto
  • Determines Kernel Cache.
Kernel>Quirks
QuirksValueNotes
AppleCpuPmCfgLockYES
  • Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in AppleIntelCPUPowerManage- ment.kext, commonly causing early kernel panic, when it is locked from writing.
  • Enable this quirk if you cannot disable CFG-Lock in BIOS/UEFI.
AppleXcpmCfgLockYES
  • Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in XNU kernel, commonly causing early kernel panic, when it is locked from writing (XCPM power management).
CustomBIOSGuidYES
  • Performs GUID patching for UpdateSMBIOSMode Custom mode.
  • This quirk is required for Dell Laptops.
DisableIoMapperYES
  • Disables IOMapper support in XNU (VT-d), which may conflict with the firmware implementation.
  • This option is a preferred alternative to deleting DMAR ACPI table and disabling VT-d in firmware preferences, which does not break VT-d support in other systems in case they need it.
  • Enable this quirk if you cannot disable VT-d in BIOS/UEFI.
PanicKNoextDumpYES
  • Prevent kernel from printing kext dump in the panic log preventing from observing panic details.
PowerTimeoutKernelPanicYES
  • Disables kernel panic on setPowerState timeout.
  • Fixes kernel panics related to power changes with Apple drivers in macOS Catalina, most notably with digital audio.
XhciPortLimitYES
  • Enables 15 port limit patch.
  • This quirk is a temporary solution and is advised to map your USB ports during post-installation.
DisableLinkeditJettisonYES
  • Disables __LINKEDIT jettison code.
  • Provides more reliable performance without keepsyms=1
  • This quirk is required for macOS Big Sur.
Note:
NVRAM>Add
UUIDKeyValueTypeNotes
7C436110-AB2A-4BBB-A880-FE41995C9F82boot-args
  • -v
  • dart=0
  • -cdfon
  • -igfxnohdmi
  • debug=0x100
  • keepsyms=1
  • alcid=11
STRING
  • Adds boot args which provides several functions.
-v
  • Enables verbose mode. Helpful to track the installation progress or when booting.
debug=0x100
  • This disables macOS's watchdog which helps prevents a reboot on a kernel panic.
keepsyms=1
  • This is a companion setting to debug=0x100 that tells the OS to also print the symbols on a kernel panic.
  • This can give some more helpful insight as to what's causing the panic itself.
alcid=11
  • Sets Layout ID = 20 for Onboard/Built-In Audio.
csr-active-config
  • 00000000
DATA
  • Defines SIP type.
00000000
  • Enables SIP completely. (0x0)
  • It's advised to configure SIP via recovery using "csrutil."
  • For more information on SIP, check the SIP disabling guide.
prev-lang:kbden-US:0STRING
  • Sets Keyboard language.
PlatformInfo
Suggested SMBIOS
SMBIOSCPU
MacBook Pro14,1Intel Skylake for i3, i5 and i7
DataHub
OptionValueNotes
Add this section in config.plistYESAdds DataHub field
Generic
OptionsValueNotes
Add this section in config.plistYESAdds Generic field
from SMBIOSYES
ProcessorType0
  • Sets SMBIOS Processor Type.
  • This will override your actual CPU type.
  • It's recommended to set this option to "0" to detect the original CPU by macOS instead of using SMBIOS CPU Type.
SystemMemoryStatusAuto
  • Indicates whether system memory is upgradable in PlatformFeature. This controls the visibility of the Memory tab in About This Mac.
Auto
  • Use the original PlatformFeature value.
  • It's recommended to set this option to "Auto."
Upgradable
  • Explicitly unset PT_FEATURE_HAS_SOLDERED_SYSTEM_MEMORY (0x2) in PlatformFeature.
Soldered
  • explicitly set PT_FEATURE_HAS_SOLDERED_SYSTEM_MEMORY (0x2) in PlatformFeature.
SpoofVendorYESSets SMBIOS vendor fields to Acidanthera
PlatformNVRAM
OptionValueNote
Add this section in config.plistYESAdds PlatformNVRAM field
SMBIOS
OptionValueNote
Add this section in config.plistYESAdd SMBIOS field.
UEFI
This section is for adding UEFI drivers and related settings. This section will remain completely untouched
Note:
The values which have been not discussed above, that will remain as default values.
Installing OpenCore EFI
2. Copy the EFI from your working directory to EFI partition of your Bootable USB Flash Drive.
Now you’ve successfully installed OpenCore, the required drivers, kexts and config.plist and the USB Flash drive is ready to boot off your computer.
UEFI Settings
SettingsValue
SATA EmulationAHCI
Network BootDisabled
Virtualization TechnologyEnabled
Legacy SupportEnabled
Secure BootDisabled
Fast BootDisabled
Once the UEFI is setup, Save & Exit Setup
Installation
Turn on your system.
6. Repeat step no. 5.
NameMacintosh HD
FormatAPFS
SchemeGUID Partition Map
12. Close Disk Utility.
This will take couple of minutes and will restart at "Less than a minute is remaining". Upon completion, the system will automatically restart. The System will restart to complete the installation. Here it ends the first phase of the installation.
Post Installation
Now, configuring the Post Installation. There is not much to do for the postinstallation except configuring WiFi/BT and the boot from system drive. Everything rest is fully functional.
DSDT and SSDT Patching
For the DSDT and SSDT patching, i prefer full patched set of DSDT and SSDT. For more information on DSDT and SSDT patching, checkout the guide linked below
https://www.elitemacx86.com/threads/guide-how-to-patch-laptop-dsdt-and-ssdts.178/
Using the guides, patch all of your DSDT and SSDT.
DSDT
  • Layout id = 11 (0x11)
  • Lenovo Ideapad-100
  • Rename GFX0 to IGPU
  • Fix _WAK Arg0 v2
  • HPET Fix
  • SMBUS Fix
  • IRQ Fix
  • RTC Fix
  • OS Check Fix (Windows 10)
  • Fix Mutex with non-zero SyncLevel
  • USB3_PRW 0x6D Skylake (instant wake)
  • GPIO Controller Enable [SKL+]
To disable the GPU, use the following patch
into method label _REG parent_hid PNP0C09 insert
begin
//added to turn nvidia/radeon off\n
If (LAnd(LEqual(Arg0,3),LEqual(Arg1,1)))\n
{\n
    External(\_SB.PCI0.RP05.PXSX._OFF, MethodObj)\n
    \_SB.PCI0.RP05.PXSX._OFF()\n
}\n
end;
SSDT
  • Cleanup/Fix Errors (SSDT)
  • Remove _PSS placeholders
The SSDT (SSDT-x0_0-Cpu0Ist) will have 2 errors in total
Find the following lines and delete them.
External (_SB_.PR00._PPC, IntObj)
External (_SB_.PR00._PSS, BuffObj)
External (_SB_.PR01._PPC, IntObj)
Patch for Disabling GPU in SSDT-9-CB-01
into method label _INI parent_label \_SB.PCI0.RP05.PXSX insert
begin
_OFF()\n
end;
Place all the patches DSDT and SSDTs to EFI/OC/ACPI
1. Open your config.plist
2. Add all the DSDT and SSDTs.
Note:
  • The DSDT and all the OEM SSDTs must be added in a sorted order.
  • The SSDT (SSDT-PNLFCFL.aml) should be added at last.
Brightness and Trackpad
The kexts for the Brightness and Trackpad already exists in the required directory and the ACPI has been patched accordingly. You just need to enable the disabled patch and kexts in your config.plist.
Boot from System Drive
3. Open your EFI Partition of your Hard Drive.
6. Copy the EFI folder from your macOS Bootable USB to your EFI Partition of your Hard Drive.
By using this method, you’ll be easily able to install OpenCore Boot loader on your System Drive.
Restart your Laptop
After completing the post installation, restart your laptop.
App Store, iMessage, FaceTime, and iCloud
1. Mount your EFI partition
2. Open your config.plist
3. Navigate to Platform Info Tab
4. Generate a new SMBIOS for "MacBook Pro14,1"
5. Save your config.plist
6. Restart your Tablet
7. Login into App Store, iMessage, FaceTime and iCloud.
Conclusion
You should have all the functions as stated above.
Credits:
Hi!
Thanks a lot for your Guide, your work and your time!
I own a new Dell Latitude 7400-5WRVH 2 in 1 (switched the SSD from 512 to Samsung EVO 1TB) Notebook and am trying to install Big Sur with OC and am following your guide.
Somehow i get stuck before Installationscreen.
My CPU is running high (at least the fan:=))
I've allready built a Hacintosh on CLOVER but it's a desktop.
Can you help me somehow plz!
I Attach my EFI folder.
Probably I'm doing some small mistake?!
Best greetings from Austria
  • EFI.zip
    EFI.zip
Hi!
Thank's for your reply!
I found a few mistakes and changed them.
I'm still stuck at the same point Stuck on or near IOConsoleUsers: gIOScreenLock as mentioned here.
Any hints? plz help
Any hints? plz help
Fix your profile first. What's the screen resolution and refresh rate?
@EliteMacx86
Could you please just send me a EFI folder for the Latitude 7400 2 in 1
I'm still strugeling...
I really do not see myself out with this millions of simular models platform ids and device ids.
1.)
As I have got a Whiskeylake CPU and it seems that I should use A53E0000 as device id as mentioned on WEG github site.
2.)
Augustowski say use this:
AAPL, ig-platform-id == 00009B3E
device-id == 9B3E0000
3.)
And here in the mentioned topic th solution is:
So I really don't know where to properly continue....
Sorry again, just trying to get things done, cause I'm probably rebooting my Laptop for the 500th time or so, since I bought it, just to get the acceleration to work.
NO.
You should consider reading guides and create it yourself!
@EliteMacx86
1.)
2.)
3.)
You can use both. The second ig-platform-id and device-id you mentioned, is more compatible for CFL Laptops but can be also used for WHL Laptops. However, the first one is more appropriate for WHL Laptops.
Unfortunately, you didn't provide the complete information and PR files which is necessary for debugging the issue.
Thankyou for the Guide.
In the DeviceProperties section, the key 'framebuffer-con1-enable' appears twice – is that an error? ProperTree won't allow adding the same key value.
I'm trying this on Dell 7580 which has Intel Core i7-8665U and Intel UHD Graphics 620.
Thanks for pointing it out. Probably, a typo.
Sounds good!
Reactions: dman
ramospa
