HP Elitebook 850 G6 - Intel UHD 620 - No HDMI Out
lucyjess
HP Elitebook 850 G6
Intel i7 8565U - Whiskey Lake
Intel UHD 620
10.14.x
Hi Guys.
Im hoping im able to get some assistance with this one, Im also new here so apologies if Im posting in the wrong area but I was sure to check.
HP Elitebook 850 G6
Intel i7 8565U (Whiskey Lake)
Intel UHD 620
Catalina 10.15.7
I have had some success getting the GPU working with this guide https://elitemacx86.com/threads/intel-uhd-graphics-620-630-on-laptop.207/ so thanks for that, although I am unable to get the HDMI Out to work, when I plug in a cable it displays no signal. I've tried a few different things but if im honest I am a little lost now. I have attached a copy of my EFI Folder if anyone wouldn't mind taking a look and perhaps pointing me in some directions to try!
Hi Guys.
HP Elitebook 850 G6
Intel UHD 620
Catalina 10.15.7
Incomplete PR files attached.
apologies for my ignorance, could you tell me what you need from me in addition? thanks
Well, that's already covered in FAQ. However, you'll need to attach a copy of the following
Kextcache Output
I have attached what I believe is required apologies I didn't check the FAQ I thought I had read through it all.
Here are some hints.
  • SSDT-EC and SSDT-USBX shouldn't be used together.
  • SSDT-PNLF should be used from Rehabman. If you're using from somewhere else, GFX0 must be changed to IGPU.
  • BIOS isn't relevant for your hardware. Consider removing it. With AptioMemoryFix, you shouldn't use "EmuVariableUefi.efi."
  • Use either VoodooPS2Controller.kext or ApplePS2SmartTouchPad.kext. Never both.
  • AHCIPortInjector.kext should be removed.
And these would affect cdmi not working correct? I will start installation fresh. using the guide and report back. thanks
Firstly, you should work on the main issues related to GPU, Brightness and Audio implementation which has a slight impact on HDMI. Although, for a working HDMI, Framebuffer patching is required.
I have created a new installer using the guide for Catalina, although when it boots into clover, it doesn't give display the Install Mac OS Catalina Option im confused as to why because when I did it with unibeast for my first install it worked.
Any picture for the issue? Here, we do NOT use Unibeast or other third party tools.
dmitriy103
