GUIDE How to Create OpenCore config.plist file for booting macOS on Intel Laptops
at patching DSDT and SSDT, what does this mean : ”Table Signature*” ?
on config.plist for OC the PATCH has no DSDT table. Were to add this? under ACPI/PATCH as a Children or OpenCore ->ACPI -> New Blank Entry?
this patches will patch what ? the DSDT ? if yes, then DSDT wll remain unpatched via MacIASL?
Thank u
Your question isn't clear.
i have managed to compile thoes 3 SSDT's and put them to ACPI. managed to boot the installer .
stil i did not attached the DSDT to ACPI . allso did not applied any patches (hot patch) to ACPI , i do not know how to do that.
Follow the guide linked below.
at patching under ACPI -> Patch you sayed that "used for device renames such as USB, Graphics and Audio."
on the sampleconfig.plist from OC there is no table that points DSDT.
how this Patches renames device's ? by patchind what ? the DSDT.aml ? and if yes, DSDT.aml will be the original, not patched one ?
allso how to know what patch to add to DSDT.aml ?
ACPI rename and patching is very different.
I do not understand why to dump DSDT.aml, if its not used .
at least I do not understand how to make use of it
The DSDT patching is necessary for Laptops. It has been well described in the thread linked below.
What about tiger lake processors? Is it not supported?
  • Sad
Reactions: ksn96
alvarg82
