Hi i have a problem in big sur how can i copy hda-verb to bin also jack fix too because big sur not allow write system file. Thanks
You can enable write access. The guide will be updated soon for macOS Big Sur.
Thanx a lot for these patches! You're great. I have ALC292 with VoodooHDA. Now I've no noise in my headphones. But... Can you help me to clear the noise from my mic? In settings I use "Microphone (Digital)", and my recordings have a lot of noise. If I choose "Microphone (Pink Rear)" I have no recording at all.
Thank you!
Thank you!
Use AppleALC+Lilu.
Use AppleALC+Lilu.
I'll be glad if you help me to find right release of AppleALC and Lilu for my Dell e7240 with ALC292. Thanx! Best wishes!
Use the latest release.
Thanks! But when I'am using AppleALC or AppleHDA. Device have no sound and can't detect input and output (also I tried to change layouts in config. It has no good result. Maybe there is opportunity to delete noise in mic using VoodooHDA?
AppleALC_Lilu is preferred. If there's no sound, you should consider attaching your PR files instead of using buggy VoodooHDA.
J.An
