How to Install macOS Big Sur on Unsupported Mac mini
An EliteMacx86 Exclusive Guide - This guide covers a clean installation of macOS Big Sur on Unsupported Mac mini, unofficially.
Recently, Apple announced their new macOS lineup i.e macOS Big Sur 11.0 which is Apple's newest and most awaited OS. Mojave adding massive updates and improvements from its predecessor, High Sierra.
Packed with new features and functionality, the most noticeable update can be seen and experienced is the new GUI. Featuring a much more "iOS" look and feel and as smooth as butter. With each release of macOS, Apple remove supports for old hardware.
Unfortunately, with the the release of macOS Big Sur, Apple has officially dropped support for Mac mini 2009, 2010, 2011 and 2012. Luckily, for our users and readers though, we're going to provide you a complete installation guide step-by-step.
If you've made and attempt to install macOS Big Sur before reading this guide, you've probably been greeted with the prohibited or no-entry sign immediately after booting from the Big Sur installer.
With this in mind, you'll have to use other way to get macOS Big Sur on your unsupported Mac Pro. Previously, Dosdude, did an excellent job for running macOS on unsupported Macs. From macOS Sierra to Catalina. As there's no any work for macOS Big Sur from Dosdude, a thread is available by him which is linked below.
macOS Big Sur Compatibility
Mac mini (Late 2014) and later Mac mini models supports macOS Big Sur, natively. Refer to the chart below to confirm the compatibility of your Mac mini.
ModelSMBIOSmacOS Big Sur Support
Mac mini (Early 2006)Macmini1,1❌
Mac mini (Mid 2007)Macmini2,1❌
Mac mini (Late 2009)Macmini3,1❎
Mac mini (Mid 2010)Macmini4,1❎
Mac mini (Mid 2011)*Macmini5,1*❎
Mac mini (Mid 2011)*Macmini5,2*❎
Mac mini (Server, Mid 2011)*Macmini5,3*❎
Mac mini (Late 2012)Macmini6,1❎
Mac mini (Server, Late 2012)Macmini6,2❎
Mac mini (Late 2014)Macmini7,1
Mac mini (Late 2018)Macmini8,1
❌ = Completely unsupported in any means.
❎ = Unofficially supported
= Officially supported.
Note:
  • *Requires a Metal-compatible GPU or there will no Graphics acceleration.
Have another Mac model and want to run macOS Big Sur? You can find the complete list of supported Mac models for macOS Big Sur and check whether your Mac model is listed. The compatibility list is linked below.
Have another Unsupported Mac other than a Mac mini and want to run macOS Big Sur? Check out our exclusive installation guide for Unsupported Mac Pro and iMac below.
For Unsupported Mac Pro
For Unsupported iMac
Before you start with this guide, here are the requirements for setting up macOS Big Sur on your unsupported Mac mini.
Mac miniLate 2009, Mid 2010, Mid 2011, and Late 2012
Boot ROM VersionLatest Boot ROM available
USB Flash DriveAt least 16GB
If you meet the above requirements, you're good to go and can start with the guide.
The next steps are continued in the post #2 of this thread for continuing with the preparing and patching the USB installer.
Reactions: dalquest
Create a Backup of your Mac
Before you proceed with the installation, we advise you to perform a backup of your Mac. In case the installation fails or you encounter any issue with the installation, you can roll back to your existing installation.
To create Backup for your Mac, follow the guide below
Download macOS Big Sur
The next step is to download macOS Big Sur. Normally, you won't be able to get new updates as you're using unsupported Mac and Apple will block updates for new OS. However, there's another workaround available and you can download the copy of macOS Big Sur very easily. To download macOS Big Sur, follow the guide below
Creating macOS Big Sur Bootable USB
After downloading macOS Big Sur, the next step is to create the Bootable USB for macOS Big Sur. To create macOS Big Sur Bootable USB, follow the guide below
Note:
As you've already downloaded macOS Big Sur, so just continue with the createinstallmedia step to create your Bootable USB
Preparing the USB Installer
The next step is to prepare the USB installer for booting macOS Big Sur. Before you start preparing the USB installer, check the macOS version support below for patching the USB installer.
Micropatcher VersionmacOS Version
v0.5.1macOS Big Sur (20C5048l)
v0.5.1macOS Big Sur (20B29)
v0.5.1macOS Big Sur (20B28)
v0.5.1macOS Big Sur (20B5012d)
v0.5.1macOS Big Sur (20A5395g)
v0.4.2-v0.4.4macOS Big Sur (20A5395g)
v0.4.2-v0.4.4macOS Big Sur (20A5384c)
v0.4.2-v0.4.4macOS Big Sur (20B5012d)
Patching USB Installer
The next step is to run micropatcher to patch the USB installer. To patch your USB Installer, follow the steps below.
1. Download Micropatcher
2. Extract the Micropatcher to your Desktop
3. Open Terminal and type the commands below
/Users/yourusername/Desktop/big-sur-micropatcher-0.5.1\ 2/micropatcher.sh /Volumes/Install\ macOS\ Big\ Sur
You should see something similar like the screenshot attached below.
/Users/yourusername/Desktop/big-sur-micropatcher-0.5.1\ 2/install-setvars.sh /Volumes/Install\ macOS\ Big\ Sur
Notes:
  • It's recommended to use the latest version of micropatcher to avoid issues.
  • You must replace "yourusername" with your actual username otherwise the command will not work.
  • Letters and spacings are case-sensitive.
Running setvars EFI Utility
Once you're done with the above steps, you'll need to run servars EFI utility which will allow to boot macOS Big Sur. To setup setvars on your Mac mini, follow the steps below.
1. Restart your Mac mini and while restarting, hold down the option key and boot from "EFI Boot".
Note:
Once you boot from EFI boot, your Mac mini will shut down. This is an indication that the setvars EFI utility has successfully finished making necessary changes to your Mac mini's NVRAM settings. These changes include disabling SIP, disabling authenticated root, and enabling TRIM on non-Apple SSDs.
#3 of this thread for continuing with the installation.
Booting the macOS Installer
Once you finish setting up setvars EFI utility, you're ready to install macOS Big Sur on your Mac mini.
1. Start your Mac mini and while restarting, hold down the option key and boot from "Install macOS Big Sur". The installer will load in a while.
2. When at installation screen, select your preferred language and continue
3. Select Disk Utility and continue, click on View and select Show all Devices.
4. Now select your Hard Drive or SSD on which you want to install macOS and use the following parameters to erase your drive.
OptionsValue
NameMacintosh HD
FormatAPFS
SchemeGUID Partition Map
5. Close Disk Utility
6. Select Install macOS Big Sur and continue with the options.
7. Now select Macintosh HD and click on Continue.
Note:
This will take couple of minutes and will restart at "Less than a minute is remaining". Upon completion, your Mac mini will automatically restart and continue the installation further.
8. When your Mac restarts, select Boot macOS Install from Macintosh HD and then boot.
It will continue the second phase of the installation. Upon completion, your Mac will automatically restart.
9. When you're at the welcome screen, continue with the basics options such as Keyboard setup, Network, Computer Account and Privacy settings.
Notes:
  • If you get a prohibited or no-entry sign when booting the installer, restart your Mac and boot from "EFI Boot". You need to follow the steps from "Running setvars EFI Utility" mentioned above. Make sure you boot using the "external" (yellow color) EFI boot which represents your USB Installer.
  • During the installation process, your Mac might restart several times. You might get blank screen at certain times but that's normal and the installer is still working in background.
  • The first boot maybe slower as the caches are not build yet. Once the caches are built, it will boot normally.
The next steps are continued in the post #4 of this thread for continuing with post-installation.
Post Installation
After installation, Post Installation needs to be performed. The post installation is required to achieve the fully system functionality.
Typically, the post installation includes enabling boot from the system drive, Graphics, Network, Audio, USB Ports Mapping, and Power Management. But for a real Mac, you just need to patch kexts and setup booting from System Drive using OpenCore.
Patching Kexts
After completing the installation, you need to patch the kexts for making WiFi, BT and USB ports functional.
To patch the kexts, follow the steps below.
1. Open your USB Installer which is named as "Install macOS Big Sur."
2. From Spotlight search, find and open Terminal
3. In Terminal, type the following command below
/Volumes/Install\ macOS\ Big\ Sur/patch-kexts.sh
4. When prompted, enter your password.
5. The script will start to patch the kexts. Once it finishes the process, you should see something similar like the screenshot attached below.
6. Quit Terminal
7. Restart your Mac mini.
Note:
Letters and spacing are case-sensitive.
#5 of this thread for continuing with OpenCore installation.
Now, the installation is complete but you might have been wondering why OpenCore is needed on a real Mac? The answer is simple, your Mac mini will lack macOS update function. To enable macOS updates, you'll need to use OpenCore. OpenCore will provide you seamless updates just like a supported Mac mini under Software Update in System Preferences.
Preparing OpenCore Bootloader
DirectoriesPurpose
DocsContains documentation, change log, a sample config.plist, and ACPI Samples for OpenCore
IA32Contains OpenCore EFI, 32-bit OpenCore Boot Loader
UtilitiesContains several utilities
x64Contains OpenCore EFI, 64-bit OpenCore Boot Loader
Adding Required Drivers
Drivers are mandatory which allows several important function and is required to boot the system. Follow the steps below to add the drivers.
Driver NameRequiredNotes
OpenCanopy.efiYES
  • Provides GUI functionality for OpenCore Boot screen. This driver is required for GUI or theme for OpenCore.
OpenRuntime.efiYES
  • Runtime driver including several other drivers merged such as ApfsDriverLoader. OpenRuntime.efi is a replacement for AptioMemoryFix.efi driver.
All the drivers can be found at: X64/EFI/OC/Drivers
Adding Required Kexts
Kext NameRequiredNotes
Lilu.kextYES
  • Provides arbitrary patching.
WhateverGreen.kextYES
  • Provides GPU patching on macOS.
  • This kext requires Lilu.kext to function
1. Download the above kexts.
Notes
  • Do not download the project files. The pre-built binaries/downloads are available in the README.md section. Make sure you read it carefully.
  • Use the kext from RELEASE folder and RELEASE.zip file.
  • Do not place any other kexts here. It might prevent booting the installer.
Selecting a Config.plist File
OpenCore comes with a default config.plist file. This config.plist cannot be used to boot your Mac. You'll need to configure the config.plist according to your hardware, mainly graphics and other devices.
We've already created a separate thread on configuring your config.plist to boot the installer. Depending on your Mac model, create a config.plist according to the guide. For more information on creating a config.plist, follow the guide below.
Installing OpenCore Bootloader
1. Mount the EFI partition of your system drive.
2. Copy the prepared EFI from your working directory to your system drive.
Boot from System Drive
This is one of the most important part as it will allow you to boot from OC from your EFI partition.
1. Download Bless OpenCore
2. Extract it.
3. Right click on Bless OpenCore and click on Open.
4. It will ask you for a password. Enter your password and click on OK and it will make the necessary changes.
5. Restart your Mac mini
By using this method, you’ll be easily able to boot OpenCore Boot loader from your System Drive.
Notes:
  • Always use right click and then run Bless OpenCore or it may fail to make the necessary changes.
  • For sometimes, the OpenCore may not start at the first boot. To verify, use Hackintool to check the Board ID. A workaround this issue is to repeat the process of Bless OpenCore.
Now you’ve successfully installed macOS Big Sur, and configured it. The installation is complete!
Enjoy macOS Big Sur on your unsupported Mac mini :)
Hi, I'm using a MacMini 3,1 and it runs Catalina with DosDude patcher. I created the Big Sur installer exactly following this manual. Big Sur starts, but at about 1/3 of the progress bar, I get a prohibited sign, so I never reach the installer screen. I did boot from the EFI first and tried the cycle over and over, but always get stuck at about 1/3 of the first progression bar. Does anyone know of a way to fix this or what is causing this issue?
Thanks in advance!!
Thanks in advance!!
What Micropatcher and macOS version are you using?
Hi! I used the latest micropatcher 0.5.1 and prepared the Big Sur installer USB from Catalina (DosDude patched MacMini), High Sierra Hackintosh and from a MacMini 2014 running Mojave. They all give the same result when installing Big Sur in my MacMini 3,1...prohibited sign at 1/3 of the progress bar.
You must use the same Mac mini to prepare the installer on which you wish to run macOS Big Sur.
I used the same MacMini 3,1 the first time to create the Big Sur micropatch installer, but it is running Catalina from APFS with DosDude1 patcher. could that ne the culprit? Do I have to prepare the USB on yje same MacMini 3,1 but running a native supported OSX version?
Roberto Sales
