hey Great Post.
So I have a very similar Hackintosh.
I'm a beginner on the Hackintosh world, and at the moment I'm stuck where you said to change the ACPI as I've never used MACIA before :(
If you could spare some time to help a newbie trying to get my work done, I would be very thankful mate.
You can follow the guide.
Hi, I have a bit of problems: if I have your patch installed and have iGPU enabled, my Thunderbolt stops working. I have a HDD box and the OS won't recognize the drives. Sometimes it will recognize the drives and mount it, but the disk is completely not accessible and causes Finder to freeze. I have Z390 Aorus Pro motherboard and GC Titan Ridge 2.0. Any ideas?
No PR files attached.
Right I think I've managed to edit, although I couldn't find the "RP 05"
Could you please tell me what are I'm doing wrong?
Cheers
Cheers
It looks like you have not read the guide carefully.
Your ACPI path is PEG1 not RP05. Secondly, you're editing the wrong SSDT. You need to edit SSDT-Z390-TB3HP
I'm really sorry, I was using the older version of MaciASL which wasn't allowing me to edit the SSDT-Z390-TB3HP.
Anyway after following all the steps I got a message at the BOOT screen saying there's a error as you can see on the bellow image
  • Roberto P 2.zip
    Roberto P 2.zip
Anyway after following all the steps I got a message at the BOOT screen saying there's a error on the Thunderbolt_Reset.Kext
- Incomplete PR files attached. Kextcache output and IOReg is missing.
- Your configuration is not as per the guide.
Hi @EliteMacx86, I own an Asus Prime Z370-A with the ThunderboltEX 3 card and I believe that it doesn't change much for the hardware used in your guide.
If you can help me, I'm attaching everything you asked for. Recalling that I have already done all the Guide to enable Thunderbolt 3 processes.
On Windows, I already installed the driver available on the Asus website and you can see my Apple Thunderbolt monitor working perfectly (sound, USB and camera).
If anything is missing, I'm sorry. I'll send it next.
  • IOReg-iMac-Berga.zip
  • OC-Berga.zip
    OC-Berga.zip
wyattst99
