[Guide] Gigabyte GA-H110M-S2 - Intel Core i5 7400 - NVIDIA GeForce GT 710
I am not able to install ethernet drive on my hackintosh catalina i followed your mathod
Install Realtek Ethernet kext as per the guide.
Complete installation guide for installing macOS Mojave 10.14 (18A391) on a Custom Build PC Specifications : Motherboard : GA-H110M-S2 CPU: Intel Core i5 - 7400 RAM: 8 GB 2400MHz IGPU: Intel HD Graphics 630 Graphics: NVIDIA GT 710 SSD: Samsung SSD 850 EVO 250GB Audio: Realtek ALC 887 Display: 21.5" (1920x1080) Summary : What's works? Audio Graphics Ethernet HDMI Power Management iMessage FaceTime iCloud USB 2.0, 3.0 Ports Not working Everything works Bootable Media Creation STEP 1 To create Bootable USB for installation Insert USB Flash Drive and open Disk Utility Select USB Flash Drive and Erase it with following parameters Name : USB Format : OS X Extended (Journaled) Scheme : GUID Partition Map Launch Terminal Copy and paste the following sudo command in terminal
Enter Password, when it asks Press (Y) for confirmation of the proceeding process and press Enter key Close Terminal after execution of the process STEP 2 Download Clover EFI Bootloader from the Forum Downloads Section Run Clover EFI bootloader installer package In Clover Bootloader click on Change Install Location and select installation Drive i.e Install macOS Mojave. Click on Customize and configure the following settings. Install Clover for UEFI booting only Install Clover in the ESP Themes: Select any Drivers64UEFI: AptioMemoryFix-64 , ApsDriverLoader-64 Confirm the above options and click on Install. Enter Password when it asks. Click on Close after execution of the process STEP 3 : Now you'll have to place the necessary Files, Kexts & Config.plist Navigate to: EFI/CLOVER Download the Config.plist file from here: https://www.elitemacx86.com/threads/guide-creating-a-basic-config-plist-file-for-booting-macos.257/ Change the SMBIOS to iMac 18,2 Rest will be as it is Navigate to: EFI/CLOVER/drivers64UEFI/ Place HFSPlus.efi : https://github.com/JrCs/CloverGrowerPro/raw/master/Files/HFSPlus/X64/HFSPlus.efi After that Navigate to: EFI/CLOVER/kexts/ Place following kexts in the folder FakeSMC.kext: https://github.com/RehabMan/OS-X-FakeSMC-kozlek VoodooPS2Controller.kext: https://github.com/RehabMan/OS-X-Voodoo-PS2-Controller USBInjectAll.kext: https://github.com/RehabMan/OS-X-USB-Inject-All Lilu.kext: https://github.com/acidanthera/Lilu WhateverGreen.kext: https://github.com/acidanthera/WhateverGreen Now, everything is done USB is fully prepared for installation UEFI settings Set Network Stack to Disabled. Set Boot Sequence to UEFI Set Secure Boot to Disabled. Set SATA Mode to AHCI. Set VT-d Option to Disable Set Intel Virtualization Technology to Enabled Set Fast Boot to Disabled Booting the Installer using USB After preparing installation USB Plug the USB flash drive in USB 2.0 port and boot to boot menu Select USB with the UEFI prefix and press enter to boot Use following boot args : -v Select Boot macOS Install from Install macOS Mojave and press enter to boot When at installation screen select preferred language and continue Select Disk Utility and continue click on View and select Show all Devices select Hard Drive or SSD on which you want to install macOS Select the Drive and click on Erase button Erase it with following parameters Name : Macintosh HD* (You can rename it later on) Format : APFS Scheme : GUID Partition Map After execution of the process Close Disk Utility Select Install macOS and continue with the options. Now select Macintosh HD* and click on Install. When the PC restarts, select Boot macOS Install from Macintosh HD or (Drive name) and press enter After installation, boot it using USB, but this time select Macintosh HD or (Drive name) and press enter When you're at the welcome screen, continue with the basics options such as Keyboard setup, Network, Computer Account and Privacy settings Post Installation Boot from System Drive Mount the EFI Partitions of BOTH USB as well as Hard Drive/SSD Open EFI Partition of Hard Drive Select EFI folder and then move to Trash Open EFI Partition of USB Copy the EFI folder to EFI Partition of Hard Drive. Graphics NVIDIA GT 710 is supported and will run in full QE/CI OOTB Network The PC uses Realtek RTL 8111 Ethernet Chipset. Install Realtek RTL8111.pkg Audio The PC uses a Realtek ALC 887 Audio Codec Download AppleALC.kext & Lilu.kext Move the files to EFI/Clover/Kexts/10.14 and place both the kexts Open config.plist Use layout ID = 11 Check "ResetHDA" USB Ports All USB Ports works OOTB Add USB port limit patch Mount EFI Partition Open config.plist file using Clover Configurator Navigate to kernel and kext patches tab and add the following patch in config.plist.
 Name: com.apple.driver.usb.AppleUSBXHCI Find* [HEX]: 83FB0F0F 83030500 0 Replace* [HEX]: 83FB0F90 90909090 90 Comment: USB 10.14.x by PMHeart MatchOS: 10.14.x
Save config.plist file Restart PC for implementing the changes Miscellaneous App Store iMessage FaceTime iCloud To activate App Store iMessage FaceTime & iCloud, follow the instructions below : Mount EFI partition Open config.plist Navigate to SMBIOS Tab Generate a new SMBIOS for "iMac 18,2" Save config.plist Restart PC Login into App Store, iMessage, FaceTime and iCloud. By following the above Guide, A full working macOS Mojave on Custom Build PC can be installed Credits: A special Thanks to @EliteMacx86 for the wonderful guides which is super easy to follow.
i have i5-7400 with gigabyte h110m s-2 and igpu
i have installed the mac os Catalina but my Ethernet and audio is not working please help
I have a question, I have i5 7400 with intel 630 graphics, and I need to install macos and I wanted to know if with this I can start applications such as imovie, icloud, itunes, etc. Can this guide help me ?. Right now I have the latest version of Catalina installed on my hackintosh, but I can't get it to detect my igpu.
Yes, those all will work. You can follow the guide.
Specifications :
RAM: 8 GB 2400MHz
Summary :
What's works?
Audio
Ethernet
HDMI
Power Management
iMessage
FaceTime
iCloud
USB 2.0, 3.0 Ports
Not working
Everything works
STEP 1
Format
Scheme
Launch Terminal
STEP 2
Themes: Select any
STEP 3 :
After that
UEFI settings
-v
Format
: APFS
Post Installation
Network
Audio
Open config.plist
Use layout ID = 11
Check "ResetHDA"
USB Ports
Mount EFI Partition
MatchOS: 10.14.x
App Store
iMessage
FaceTime
iCloud
Mount EFI partition
Open config.plist
Save config.plist
Restart PC
Credits:
Efi folder please!!!
ryusuke17
