Please fix your profile first.
  • config.plist is not as per the guide.
  • ACPI is not patched.
  • The drivers directory is not as per the guide.
  • Remove all the kexts installed in S/L/E.
Also, the AppleHDA looks modified and you're also using AppleALC. You should choose only one method.
Thanks for your reply,
alright I'll have to check all of what you've suggested
    How should it comply, where are the missing parts?
    The system is fully operational without patching, I've never used this method before but after reading online about the process more in depth, is there a specific patch just for audio or I have to patch the whole system
    where should I place them?
    and install them where? EFI?
  • Also, the AppleHDA looks modified and you're also using AppleALC. You should choose only one method.
    AppleALC is not loading in the first place
    AppleHDA, I searched for layout id in AppleHDA.kext/Contents/PlugIns/AppleHDAHardwareConfigDriver.kext/Contents/Info.plist , Codec ID is 283902515 = 0x10EC0233 while it should be 283902517 = 0x10EC0235 for ALC233
    DPCIManager/Status listing codec id as 0x10EC0235
I already linked the guide above.
ACPI patching is necessary for Laptops. For more information, read here:
Again, i liked the installation guide above.
Of course. You have got many unnecessary kexts installed.
This is not the correct method. To implement Audio on Laptops, you must patch DSDT, inject a proper layout ID for the Codec in your config.plist and pair it with AppleALC+Lilu. For more information, read here:
Alright, thanks a lot
I installed codeccomander and vodoohda via kextBeast.
As per the guide, you must use one method only. You're using AppleALC and VoodooHDA which is not recommended.
So I need to try commander only?
I removed AppleALC and VoodooHDA (only CodecComm in efi) and now when im trying to run a script im getting this error: "Could not locate CodecCommander kext, ensure it is loaded." (and I have no sound at all lol)
kextcache output:
viktor@Air-Viktor ~ % sudo kextcache -i/
Password:
kextcache -i/
kextcache -arch x86_64 -local-root -all-loaded -kernel /System/Library/Kernels/kernel -prelinked-kernel /Library/Apple/System/Library/PrelinkedKernels/prelinkedkernel -volume-root / /Library/Extensions /AppleInternal/Library/Extensions /Library/Apple/System/Library/Extensions /System/Library/Extensions
KernelCache ID: 00CFFB6C4709541F901C6FAFAEF38FEB
kextcache output:
Password:
kextcache -i/
Please follow the guide properly. All steps has been provided. If you're unable to understand anything, reply to this thread. Again, your configuration is not proper. I suggest to fix that first.
When I following guide step by step I'm getting "Could not locate CodecCommander kext, ensure it is loaded." May be problem in opencore bootloader? My way to cc next is EFI/OC/Kexts/cc.kext
GabyXB
